Powershell Script and WinSCP
Juneb
U.S.
Hi All -
I was wondering if i could get some assistance with a powershell/winscp script I am building. It will run in task scheduler every hour, daily, between a certain time slot. The script works - meaning it connects to the remote site and downloads the file(s). What I need, or would like is to pull the file names that were downloaded from the log file created by winscp, and have the names in the email body. Below is the sample script...any help is appreciated.
Clear-Host
$date = Get-Date -format "yyyy-MM-dd HH"
$BaseDir = "SomePath\"
$FileDir = "SomePath\"
Set-location $BaseDir
# Get File - Time Set in Task Scheduler
.\WinSCP.exe /console username@somewhere.com /script=Script.txt /Log=LogFiles/Log-$Date.log
Sleep 120
# Check if File(s) Exists After Download completes
$File = Get-ChildItem "SomePath\*.txt" | where {$_.LastWriteTime.Date -eq ($Date)}
$Checkfile = test-path $File
Get-Content Log-$Date.log
If ($Checkfile -eq $True)
Send-MailMessage -To "someone" -From "someone" -Subject "The File Has Downloaded" -SmtpServer "10.10.10.10"
else
Juneb
Re: Powershell Script and WinSCP
Thanks, I noticed the assemblies after i published the forum note. We are running 4.2.9 of winscp at the moment. Is the .Net Assemblies available with 4.2.9, or just the later versions of winscp?
Just 5.x.
namerg
Could not load file or assembly
I am trying to upload a file to an ftp site using winscp 5.1.5 through PowerShell but get the following error:
Could not load file or assembly 'WinSCP.dll' or one of its dependencies. Operation is not supported. (Exception from HRESULT: 0x80131515)
Re: Could not load file or assembly
See https://winscp.net/forum/viewtopic.php?t=12006
If it does not help, please continues on that topic. This topic is not relevant to your problem.
Southjam
you have to add the path to where the dll is located.
# Load WinSCP .NET assembly
this is for a 64 bit machine of course.
