uploading a file through command line with SSH
Greg T
Been wrestling with this all morning and hit a point where I need to raise my hand for some assistance.
Here is my line I'm running and output
winscp /command "option batch abort" "option confirm off" "open sftp://user:password@remotesite.com -hostkey="ssh-rsa 1024 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx" "put -nopreservetime tester.txt" "exit"
Searching for host...
Host does not exist
batch abort
confirm off
Connecting to host...
Authenticating...
Using username "user".
Authenticated.
Starting the session...
Reading remote directory...
Session started.
Active session: [1] user@remotesite.com
Unknown command '1024'.
when I run it in these chunks it works without issue. Just combined it complains. Any thoughts?
so I'm thinking it's syntax at this point. I just don't see it at this point. Any help?
Re: uploading a file through command line with SSH
You need to double the double-quotes around command arguments:
winscp /command "option batch abort" "option confirm off" "open sftp://user:password@remotesite.com -hostkey=""ssh-rsa 1024 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx""" "put -nopreservetime tester.txt" "exit"
See:
https://winscp.net/eng/docs/commandline#syntax
