Saving the console output to a text file? then hide console
3K
Geneva
When running a script, a console output appears showing a concise status. How can I save this console output to a text file and hide the console? (I use the /log="logfile.txt" but it's long.)
Thank you. :)
Re: Saving the console output to a text file? then hide console
I recommend you use XML logging:
https://winscp.net/eng/docs/logging_xml
If you insist on what you see on the console, you would have to write a wrapping application or script that runs hidden WinSCP, and redirects its output into its own stream.
https://winscp.net/eng/docs/guide_automation_advanced
Or use .NET assembly with its Session.OutputDataReceived event
https://winscp.net/eng/docs/library_session_outputdatareceived
3K
Geneva
I've tried the command below where it saved the console output to myconsole.txt. However, when I opened it, there is no line break/return key. Any idea how to insert a line break automatically?
winscp /log="mylogfile.txt" /xmllog="myxmllog.xml" /script="test.txt" >myconsole.txt
Thank you. :)
lochun
Hi 3K
Hi 3K the file myconsole.txt is blank for me when i am trying to concatenate the output in the text file. which version of WINSCP you are using plse?
my code is
"C:\Program Files\WinSCP\winscp.exe" /console /log="mylogfile.txt" /xmllog="myxmllog.xml" /script="test.txt" >myconsole.txt
Thank you in Advance.
Thank you. :)
