Synchronize -filemask in .NET Assembly?
3K
Geneva
Hi, what is the equivalent scripting command of filemask in .NET Assembly as shown below?
Script:
synchronize -filemask="*.doc*<2012-02-01; *.ppt*<2012-02-01" local "C:\TEST\docs" "/docs"
In .NET assembly, what will be the filemask command?
synchronizationResult =
session.SynchronizeDirectories(
SynchronizationMode.Local, @"C:\TEST\docs", "/docs", false);
Thank you.
John Thomas
Malaysia
FileMask with session.PutFiles()
Does the same Filemask syntax apply to session.PutfFiles also?
I need to transfer all the files in a directory without including any sub directories and delete source files on successful transfer.
Will the following code work?
transferOptions.TransferMode = TransferMode.Binary;
transferOptions.FileMask = "*.*| */";
session.PutFiles(source\*, target, true, transferOptions);
Re: FileMask with session.PutFiles()
Your code looks good. Any problems?
