Crash when set remote/remembered directory does not exist.
Simba
There seems to be a problem when set remote directory setting or remembered directory does not exist.
It just keeps waiting for the directory with crash.
Also if i empty remote directory setting line, it still can't find it. It should then use default.
WinSCP 5.0.6 beta
Simba
Update: it happens when using FTP with some encryption (like TLS) and server or program cannot handle it. It just keeps retrieving directory listings (which program does not understand) then it gets too many connections from one IP).
Re: Crash when set remote/remembered directory does not exist.
