Syncronize Command failing / Large Files
I am using the following script to syncronize 2 locations:
option batch abort
open wolfe
option transfer binary
synchronize local -delete -speed=2048 D:\IRIS2DBBackup\DBBackup\backup\ //srv/nfs/backup
close
The remote location consists of 5 files of between 60MB and 10MB, 2x 0KB files and 4x files of 20GB each.
A couple of weeks ago it just stopped copying the large files (the 20GB ones)- everything else copies successfully.
I initially thought it was being caused by slowness re-exchanging the SSH keys so I changed the Max minues and Max data settings to 0. That hasn't helped.
The end of the log files is below.
Any help / ideas greatly appreciated.
. 2012-03-15 02:01:20.185 File: "//srv/nfs/backup/rman_bckup_db_IRISDB_777938597_15019_1"
. 2012-03-15 02:01:20.185 Copying "//srv/nfs/backup/rman_bckup_db_IRISDB_777938597_15019_1" to local directory started.
. 2012-03-15 02:01:20.185 Binary transfer mode selected.
. 2012-03-15 02:01:20.185 Checking existence of partially transfered file.
. 2012-03-15 02:01:20.185 Opening remote file.
> 2012-03-15 02:01:20.185 Type: SSH_FXP_OPEN, Size: 72, Number: 1327619
< 2012-03-15 02:01:20.185 Type: SSH_FXP_STATUS, Size: 24, Number: 1327364
. 2012-03-15 02:01:20.185 Discarding reserved response
< 2012-03-15 02:01:20.200 Type: SSH_FXP_HANDLE, Size: 13, Number: 1327619
> 2012-03-15 02:01:20.200 Type: SSH_FXP_FSTAT, Size: 13, Number: 1327880
> 2012-03-15 02:01:20.200 Type: SSH_FXP_READ, Size: 25, Number: 1328133
. 2012-03-15 02:01:20.200 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
< 2012-03-15 02:01:20.200 Type: SSH_FXP_ATTRS, Size: 37, Number: 1327880
. 2012-03-15 02:01:20.200 Storing reserved response
. 2012-03-15 02:52:31.469 376712 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2012-03-15 02:52:31.469 Type: SSH_FXP_CLOSE, Size: 13, Number: 49547780
* 2012-03-15 02:52:31.469 (ECommand) Copying files from remote side failed.
* 2012-03-15 02:52:31.469 Timeout waiting for external console to complete the command.
< 2012-03-15 02:52:37.469 Script: 'D:\IRIS2DBBackup\DBBackup\backup\RECOVER_DB_UNTIL_SCN_5507606078' deleted
< 2012-03-15 02:52:37.766 Script: 'D:\IRIS2DBBackup\DBBackup\backup\rman_bckup_arc_IRISDB_777856754_15003_1' deleted
< 2012-03-15 02:52:37.985 Script: 'D:\IRIS2DBBackup\DBBackup\backup\rman_bckup_arc_IRISDB_777856754_15004_1' deleted
< 2012-03-15 02:52:38.204 Script: 'D:\IRIS2DBBackup\DBBackup\backup\rman_bckup_arc_IRISDB_777856754_15005_1' deleted
. 2012-03-15 02:52:38.204 Script: Failed
. 2012-03-15 02:52:38.204 Closing connection.
. 2012-03-15 02:52:38.204 Sending special code: 12
. 2012-03-15 02:52:38.204 Sent EOF message
Sorry - should have said that that I am using SFTP (although SCP fallback is ticked too).
. 2012-03-15 02:00:01.186 --------------------------------------------------------------------------
. 2012-03-15 02:00:01.186 Session name: wolfe (Stored session)
. 2012-03-15 02:00:01.186 Host name: wolfe.iris.bh.uk (Port: 22)
. 2012-03-15 02:00:01.186 User name: root (Password: Yes, Key file: No)
. 2012-03-15 02:00:01.186 Tunnel: No
. 2012-03-15 02:00:01.186 Transfer Protocol: SFTP (SCP)
. 2012-03-15 02:00:01.186 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2012-03-15 02:00:01.186 Proxy: none
. 2012-03-15 02:00:01.186 SSH protocol version: 2; Compression: No
. 2012-03-15 02:00:01.186 Bypass authentication: No
. 2012-03-15 02:00:01.186 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2012-03-15 02:00:01.186 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2012-03-15 02:00:01.186 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2012-03-15 02:00:01.186 SFTP Bugs: -,-
. 2012-03-15 02:00:01.186 Return code variable: Autodetect; Lookup user groups: Yes
. 2012-03-15 02:00:01.186 Shell: default
. 2012-03-15 02:00:01.186 EOL: 0, UTF: 2
. 2012-03-15 02:00:01.186 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2012-03-15 02:00:01.186 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2012-03-15 02:00:01.186 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2012-03-15 02:00:01.186 Cache directory changes: Yes, Permanent: Yes
. 2012-03-15 02:00:01.186 DST mode: 1
. 2012-03-15 02:00:01.202 Looking up host "wolfe.<removed>"
. 2012-03-15 02:00:01.264 Connecting to 10.<removed> port 22
. 2012-03-15 02:00:01.561 Server version: SSH-2.0-OpenSSH_4.3
. 2012-03-15 02:00:01.561 Using SSH protocol version 2
. 2012-03-15 02:00:01.561 We claim version: SSH-2.0-WinSCP_release_4.3.6
. 2012-03-15 02:00:01.577 Doing Diffie-Hellman group exchange
. 2012-03-15 02:00:01.733 Doing Diffie-Hellman key exchange with hash SHA-1
. 2012-03-15 02:00:02.108 Host key fingerprint is:
. 2012-03-15 02:00:02.108 ssh-rsa 2048 11:a0:53:fa:19:d6:97:a4:b8:68:2d:2d:cf:52:7c:49
. 2012-03-15 02:00:02.108 Initialised AES-256 SDCTR client->server encryption
. 2012-03-15 02:00:02.108 Initialised HMAC-SHA1 client->server MAC algorithm
. 2012-03-15 02:00:02.108 Initialised AES-256 SDCTR server->client encryption
. 2012-03-15 02:00:02.108 Initialised HMAC-SHA1 server->client MAC algorithm
! 2012-03-15 02:00:02.155 Using username "<removed>".
. 2012-03-15 02:00:02.170 Prompt (7, SSH password, , &Password: )
. 2012-03-15 02:00:02.170 Using stored password.
. 2012-03-15 02:00:02.170 Sent password
. 2012-03-15 02:00:02.202 Access granted
. 2012-03-15 02:00:02.249 Opened channel for session
. 2012-03-15 02:00:02.264 Started a shell/command
. 2012-03-15 02:00:02.264 --------------------------------------------------------------------------
mluvw47@...
Email sent.
What is the fix for this? I have encounter the same problem.
winscp438.
Thanks,
Mav
asims@...
Re: Errror
AS wrote:
Hi Can you let me know the fix too we are having the same problem
Email address enclosed asims@hotmail.com
AS
Re: Errror
The error message is as follows
2013-05-21 15:52:33.014 15 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
Re: Errror
This is not an error message. Please attach a complete session log file and describe your problem.
Samour
1 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets
prikryl,
Please let us know how this is resolved.
Re: 1 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets
Samour wrote:
prikryl,
. 2015-06-18 06:14:51.610 Using SFTP protocol.
. 2015-06-18 06:14:51.610 Doing startup conversation with host.
> 2015-06-18 06:14:51.610 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2015-06-18 06:14:51.688 Type: SSH_FXP_VERSION, Size: 33, Number: -1
. 2015-06-18 06:14:51.688 SFTP version 3 negotiated.
. 2015-06-18 06:14:51.688 Unknown server extension newline@vandyke.com="\n"
. 2015-06-18 06:14:51.688 We believe the server has signed timestamps bug
. 2015-06-18 06:14:51.688 We will use UTF-8 strings for status messages only
. 2015-06-18 06:14:51.688 Getting current directory name.
. 2015-06-18 06:14:51.688 Getting real path for '.'
> 2015-06-18 06:14:51.688 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2015-06-18 06:14:51.781 Type: SSH_FXP_NAME, Size: 43, Number: 16
. 2015-06-18 06:14:51.781 Real path is '/'
. 2015-06-18 06:14:51.781 Startup conversation with host finished.
. 2015-06-18 06:14:51.781 Listing directory "/Out".
> 2015-06-18 06:14:51.781 Type: SSH_FXP_OPENDIR, Size: 13, Number: 267
< 2015-06-18 06:14:51.875 Type: SSH_FXP_HANDLE, Size: 10, Number: 267
> 2015-06-18 06:14:51.875 Type: SSH_FXP_READDIR, Size: 10, Number: 524
< 2015-06-18 06:14:52.016 Type: SSH_FXP_NAME, Size: 3096, Number: 524
> 2015-06-18 06:14:52.016 Type: SSH_FXP_READDIR, Size: 10, Number: 780
< 2015-06-18 06:14:52.078 Type: SSH_FXP_STATUS, Size: 17, Number: 780
< 2015-06-18 06:14:52.078 Status code: 1
> 2015-06-18 06:14:52.078 Type: SSH_FXP_CLOSE, Size: 10, Number: 1028
. 2015-06-18 06:14:52.078 File: "/Out/extract_CES_SAE_v2_p0085529wjue_20150617111646.txt.pgp"
. 2015-06-18 06:14:52.078 Copying "/Out/extract_CES_SAE_v2_p0085529wjue_20150617111646.txt.pgp" to local directory started.
. 2015-06-18 06:14:52.078 Binary transfer mode selected.
. 2015-06-18 06:14:52.078 Confirming overwriting of file.
. 2015-06-18 06:14:52.078 Opening remote file.
> 2015-06-18 06:14:52.078 Type: SSH_FXP_OPEN, Size: 76, Number: 1283
< 2015-06-18 06:14:52.156 Type: SSH_FXP_STATUS, Size: 40, Number: 1028
. 2015-06-18 06:14:52.156 Discarding reserved response
< 2015-06-18 06:14:52.375 Type: SSH_FXP_HANDLE, Size: 10, Number: 1283
> 2015-06-18 06:14:52.375 Type: SSH_FXP_FSTAT, Size: 10, Number: 1544
> 2015-06-18 06:14:52.375 Type: SSH_FXP_READ, Size: 22, Number: 1797
< 2015-06-18 06:14:52.453 Type: SSH_FXP_ATTRS, Size: 29, Number: 1544
. 2015-06-18 06:14:52.453 Storing reserved response
< 2015-06-18 06:14:52.594 Status code: 1
. 2015-06-18 06:14:52.594 1 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2015-06-18 06:14:52.594 Type: SSH_FXP_CLOSE, Size: 10, Number: 2052
. 2015-06-18 06:14:52.594 Closing connection.
. 2015-06-18 06:14:52.594 Sending special code: 12
. 2015-06-18 06:14:52.594 Sent EOF message
What problem are you having?
Samour
Samour wrote:
The connection succeeded but the file failed to move, actually it move as 0% and file size is 0.
thanks,
This is the output
Authenticating...
Using username "p0085529wjue".
Authenticated.
Starting the session...
Session started.
Active session: [1] p0085529wjue@st.concursolutions.com
batch continue
reconnecttime 120
confirm off
transfer binary
Using configured transfer settings different from factory defaults.
extract_CES_SAE_v2_p0085529wjue_20150618111855.txt.pgp | 0 B | 0.0 KB/s | binary | 0%
Finished at: 06/19/2015 03:30:05 with code 0
Samour
Please find the attached,
Description: Complete log file.
Samour
This is not a log file. Please follow the instructions in my post.
Please find the attached file.
  • Download.zip (30.01 KB, Private file)
The server does not return any data for the file:
> 2015-07-08 05:10:06.999 Type: SSH_FXP_READ, Size: 22, Number: 1797
< 2015-07-08 05:10:07.077 Status code: 1
So WinSCP behaves correctly. You have to contact the server administrator or SFTP server vendor for an assistance.
Samour
Thank you.
