Dir listing and MD5 checksums - command line interface
CHARLES29020
I have two questions. I am using the WinSCP.com utility to automate file transfers. I would also like to use it to get directory listings (directory structure) of the remote locations saved back to the client computer as a text file or as XML, is this possible?
Is it possible to generate a MD5 checksum of files on the client computer and the remote computer (host) computer and save the MD5 checksums as text or XML?
I know that I can generate both from the graphical client (WinSCP.exe) but could not find information in the documentation about doing these things using the command line interface (WinSCP.com).
Thanks,
Charles
Re: Dir listing and MD5 checksums - command line interface
You can use "ls" command with XML logging
https://winscp.net/eng/docs/scriptcommand_ls
https://winscp.net/eng/docs/logging_xml
Or use .NET assembly to collect structure and save it to a file:
https://winscp.net/eng/docs/library_session_listdirectory
No. Actually even in the GUI you are limited to servers that support generating MD5 and there are only few.
