Help in my First batch code??
cva
London
I'm new to this client
am trying at command-line entry, to pull down a CSV file from below site to my local machine
ftp.xyz.com
port NUMBER 990
i',m trying at command prompt below AND Getting error message
winscp> open ftp://user:password@ftp.xyz.com:990
Connecting to ftp.xyz.com:990 ...
Connected with ftp.xyz.com:990. Waiting for welcome message...
Connection failed.
Timeout detected.
Connection failed.
Please could some one help in this?
is my syntax wrong?
and also how to write/connect above details as batch file?
NOTE:
Using below details, i can connect through File Zilla and able to import CSV file BUT I need it as batch to schedule daily
site name----> ftp.xyz.com
port NUMBER--> 990
Thanks for your time and support.
Regards,
Cva
Re: Help in my First batch code??
Port 990 suggests you should be using implicit FTPS, not plain FTP:
open -implicit ftps://user:password@ftp.xyz.com/
shruti2885
similar issue
I have a similar issue and i changed it to read open -implicit ftps://user:password@ftp.xyz.com/ but then I get host does not exist
Re: similar issue
Please post a log file (use /log command-line parameter).
