Feb 29 bug?
jblevin
Feb 29 bug?
I'm getting an scp upload error - version 5.05. It says "Invalid argument to date encode [2011-2-29]". My filesystem shows the file only as Feb 29. Is the 2011 coming from WinSCP?
TimU
Sydney
Re: Feb 29 bug?
I suggest that you should post a copy of your transfer logs here before anyone is able to advise you what the problem might be.
RobHam
Wales, UK
Re: Feb 29 bug?
I think there is a typo above and should be 2012-2-29.
Re: Feb 29 bug?
It's not a typo, the log output showed [2011-2-29]. I thought the year 2011 part might be generated by WinSCP.
In any case - in about ~5 hours from now, this will no longer be an issue :)
Re: Feb 29 bug?
