Can I run winscp from telnet?
I would like to telnet to a windows machine with winscp and then start winscp.com. However, the winscp session seems to hang. When I exit the telnet session I then get what appears to be all of the winscp console output at once. Is there any way to run winscp interactively from telnet, or does this not work?
TimU
Sydney
I haven't tried this myself, but what if you run "winscp.exe /console" from your telnet session?
Re: Can I run winscp from telnet?
Haven't tried that myself. In general it should work. Can you try this with the latest beta release, 5.0.6 beta?
