cd to upper level moves cursor to the '..' item
vlad
Hi Martin,
with new version when I change directory back one level higher, far cursor supposed to stay on the directory where I cd out from, but instead it stays on '..' item.
Vlad.
vlad
error
Also,
just got this phantom error, while it was calculating dir size before copying dir structure
╔═════ Error ══════╗
║ EAccessViolation ║
║ Ok ║
I could not reproduce it again by copying the same dirs... it's one of these random errors that pop up ocasionally and that I told u about earlier.
Vlad
Re: cd to upper level moves cursor to the '..' item
I have noted it already too. I'll fix it.
