I cannot drag files from desktop to remote server
Alexion
Does anybody how to activate the dragging of files from local computer to remote server? On my old computer it did work just fine.
BTW dragging files from the remote server to my desktop does work ok.
I have activated the Prefferences > transfer > Drag & drop > Allow moving... (using Shell ext).
I'm using winscp on a Win7 64bit proffesional.
Alexion
Groningen
PS I'm using WinSCP version 5.0.5 (1782)
!!! when changing back to 4.3.7 it works again !!!
Is 5.0.5 buggin' ?
Re: I cannot drag files from desktop to remote server
Alexion
Groningen
Downloaded, executed and logfiles send. 8)
Why do you want to drag files? Instead of dragging files, you can easily transfer files from your desktop to remote server using various file transfer services such as WebEx, gomeetnow, gotomeeting etc.
