Copying files to remote side failed.can't access file.
fazza1
Hi Support,
I've only just started to get the following error.
Local 'c:\ScanningDB' => Remote '/ScanningDB'
c:EMS Truck & Trailer.ddb | 0 KiB | 0.0 KiB/s | binary | 0%
Error transferring file 'c:\ScanningDB\EMS Truck & Trailer.ddb'.
can't access file.
(A)bort, (R)etry, (S)kip, Ski(p) all
Version is 4.3.2 Build 1201 on XP pro platform.
If I select S (skip) the process continues and bypass the error.
Re: Copying files to remote side failed.can't access file.
The error comes from the server.
Does it happen only with this one file or with any? Have you tried to rename the file?
