SFTPExecutable needs to be defined in app.config to point to
Hello!
Can you provide an example on how to define the SFTPExecutable in a web.config for VB.NET?
It's the only thing holding me up right now :)
Thank you very much!
samf
Do I need to wait till then next release?
The WinSCP .NET assembly will be released with the 5.0.6 beta in few weeks.
Re: SFTPExecutable needs to be defined in app.config to point to
sorry, I have no idea what the SFTPExecutable is. Can you give us more details.
I'm getting an error write over here:
With winscp.StartInfo
' SFTPExecutable needs to be defined in app.config to point to winscp.com
Try
.FileName = "C:\Program Files (x86)\WinSCP\WinSCP.exe" 'AppSettings("SFTPExecutable")
If .FileName Is Nothing OrElse .FileName.Length = 0 Then Throw (New Exception("from PutSFTP: SFTPExecutable not set in config file."))
Catch ex As Exception
errmsg = ex.Message
Return False
End Try
Thanks!
moose3322
<?xml version="1.0" encoding="utf-8" ?>
<configuration>
<startup>
<supportedRuntime version="v4.0" sku=".NETFramework,Version=v4.5" />
</startup>
<appSettings>
<add key="SFTPExecutable" value="C:\Program Files (x86)\WinSCP\WinSCP.com"/>
</appSettings>
</configuration>
bobr
If you are having trouble remembering where to modify the app.config file, look in your "Solution Explorer" window in the VB.net editor (C# and C++ might be slightly different). I use various editors, so sometimes it is difficult to remember where everything is. My App.config looks like the following, and seems to work.
<configuration>
<startup>
<supportedRuntime version="v4.0" sku=".NETFramework,Version=v4.5.2" />
</startup>
<appSettings>
</appSettings>
</configuration>
