Problem running shell script in linux using 'call' cmd in c#
eliba3
Problem running shell script in linux using 'call' cmd in c#:
I have run the following command to run shell script but nothing happened:
winscp.StandardInput.WriteLine("option batch abort");
winscp.StandardInput.WriteLine("option confirm off");
winscp.StandardInput.WriteLine("open ilvqa1");
winscp.StandardInput.WriteLine("a1234") ;
winscp.StandardInput.WriteLine("ls") ;
winscp.StandardInput.WriteLine("cd /")
winscp.StandardInput.WriteLine("call /home/Versions/4.0.1.2/DBScripts/InfrastructureUtility/bin/Run_script")
Actually Run_script.sh is not run, Can u please help me solving this issue
Re: Problem running shell script in linux using 'call' cmd in c#
First, you probably wanted to do:
winscp.StandardInput.WriteLine("open a1234:a1234@ilvqa1");
instead of:
If this does not help, please post a log file.
eliba3
I have success connected to linux vm. so I think that the issue is not the connection.
I have a confidence problem to send you the log file:
Can u please just tell me if the following command is proper syntax for running shell script in c#?
winscp.StandardInput.WriteLine("call /home/Scripts/Run_script.sh");
( Remark I have run chmod 777 Run_script.sh before run this cmd )
eliba3
I have attached log.xml:
<?xml version="1.0" encoding="UTF-8"?>
<session xmlns="https://winscp.net/schema/session/1.0" name="pass@ilvq6n" start="2012-02-14T07:13:04.270Z">
<upload>
<filename value="c:\Run_script.sh" />
<destination value="/home/pass/QA/Versions/DD_4.0.1.2/DBScripts/InfrastructureUtility/bin/Run_script.sh" />
<result success="true" />
</upload>
<touch>
<filename value="/home/pass/QA/Versions/DD_4.0.1.2/DBScripts/InfrastructureUtility/bin/Run_script.sh" />
<modification value="2012-02-13T15:06:48.000Z" />
</touch>
<chmod>
<permissions value="rwxrwxrwx" />
</chmod>
<call>
<command value="/home/pass/QA/Versions/DD_4.0.1.2/DBScripts/InfrastructureUtility/bin/Run_script.sh" />
<destination value="/" />
<erroroutput value="Process Completed" />
<result success="false">
<message>Command '/home/pass/QA/Versions/DD_4.0.1.2/DBScripts/InfrastructureUtility/bin/Run_script.sh'
failed with return code 0 and error message
Process Completed.</message>
</result>
</call>
</session>
Yes that's correct.
As you can see from the log file, there's no actual problem. Just that WinSCP considers remote commands that has any error output as failed.
I'll change with in the next release:
https://winscp.net/tracker/797
As a workaround, you can meanwhile do:
call /home/Scripts/Run_script.sh 2>&1
(the 2>&1 redirects error output to standard output)
I have used your workaround. it works. Thanks
I have another question:
My shell script contains several sub shell commands:
i.e.
Run_script.sh file contains:
. ./Param.sh
cd "Internal"
./Installer1.sh
./Installer2.sh
cd ../
The issue is that when running Run_script.sh
( remark: Param.sh is in same work directory as Run_script.sh, and Installer1/2.sh are in internal directory. ( one directory down )
I got the following errors:
<call>
<command value="/home/Installers/Run_script.sh 2&gt;&amp;1" />
<destination value="/home/" />
<output value="/home/Installers/Run_script.sh: line 3: ./Param.sh: No such file or directory
/home/Installers/Installer1.sh: line 5: cd: Internal : No such file or directory
/home/Installers/Installer1.sh: line 7: ./Installer1.sh: No such file or directory
/home/Installers/Installer2.sh: line 8: ./Installer2.sh: No such file or directory" />
</call>
My question is: I thought that when running a shell script it will run also all sub shell scripts in the file(Run_script.sh). Same as running it from Terminal console in winscp.
Sure it does. That's why you are getting the errors.
Your script expects to be run with /home/Scripts/ as current working directory.
So you have to change to this directory before executing call:
winscp.StandardInput.WriteLine("cd /home/Scripts/");
winscp.StandardInput.WriteLine("call Run_script.sh");
Thanks. It finally works. Great !!!
Just for your info:
I got to enter the full path of the shell script although the "cd" cmd before, like:
If NOT, I got the following error:
<call>
<command value="Run_script.sh" />
<destination value="/home/Scripts/" />
<erroroutput value="-bash: line 6: Run_script.sh: command not found" />
<message>Command 'Run_script.sh'
failed with return code 127 and error message
-bash: line 6: Run_script.sh: command not found.</message>
</result>
</call>
I still got the following error in latest winscp version 4.3.7:
<call>
<command value="&quot;/home/Versions/4.0.2.0/DB Scripts/Infrastructure Utility/bin/SIS_CREATE_SH_FILES.sh&quot;" />
<destination value="/home/Versions/4.0.2.0/DB Scripts/Infrastructure Utility/bin" />
<message>Command '&quot;/home/Versions/4.0.2.0/DB Scripts/Infrastructure Utility/bin/SIS_CREATE_SH_FILES.sh&quot;'
Process Completed
</result>
</call>
Remark: I have pot the command in quot - for space 'DB Scripts'.
Is this issue should be resolved in latest version ?
eliba3
I have run the following sh file:
call /home/4.0.2.1/DB Scripts/Oracle/SIS_Run_Script_On_DB.sh 2>&1
SIS_Run_Script_On_DB.sh contains:
sqlplus QA_APP/pas@Server @Install_oracle.sql >> SISLog.log
<call>
<command value="&quot;/home/4.0.2.1/DB Scripts/Oracle/SIS_Run_Script_On_DB.sh&quot; 2&gt;&amp;1" />
<destination value="/home/4.0.2.1/DB Scripts/Oracle" />
<message>Terminated by user.</message>
</result>
</call>
What the meaning of "Terminated by user." ?
( Maybe this is the disconnect of sqlplus from the server)
Remark: Actually the SIS_Run_Script_On_DB.sh file run ok but the issue is that I cannot continue running command after this error
<call>
</result>
</call>
lpunix
how did you use this "winscp" and include it in your projeect??
can you please give me a hint about this..
i've used "ChilkatDotNet2.dll" but got problem if any other file is included in the script which i'm running from my c# code....
I says that "FILE IS NOT FOUND IN THAT PATH"....
will you give some help for winscp... :idea: :idea:
Nowdays, wou should use WinSCP .NET assembly, not the approach shown in this thread.
See https://winscp.net/eng/docs/library
sheauyun
How was this solve at the end? I think I face similar problem and have no idea to turn it around.
