HELP! I cannot move ACT database folders.
jeffpoulsen
Georgia USA
I have set up remote storage for the server and all is well except the ACT database. I am having trouble accessing it to move. Any suggestions?
_________________
Remember! Logic doesn't always work. Except it and move on.
ACT is a databas for shared information such as email, and other folders. In this case the server that is serving is a Windows 2003 Server. Below is the log
Type: SSH_FXP_CLOSE, Size: 13, Number: 7172
Type: SSH_FXP_STATUS, Size: 24, Number: 7172
Status/error code: 0
Copying 31 files/directories to remote directory "/store/M&AStorage/Shared Data/ACT Database/Database/"
PrTime: Yes; PrRO: Yes; Rght: rw-r--r--; PrR: No; FnCs: N; RIC: Yes; Resume: S (102400); CalcS: Yes; Mask: *.*
TM: M; AscM: *.*htm*; *.txt; *.php*; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
File: "D:\Shared Data\ACT Database\Database\phone.fmt"
Copying "D:\Shared Data\ACT Database\Database\phone.fmt" to remote directory started.
Binary transfer mode selected.
Opening remote file.
Type: SSH_FXP_OPEN, Size: 78, Number: 7427
Type: SSH_FXP_HANDLE, Size: 13, Number: 7427
Type: SSH_FXP_WRITE, Size: 4121, Number: 7686
3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
Type: SSH_FXP_CLOSE, Size: 13, Number: 8196
Type: SSH_FXP_STATUS, Size: 24, Number: 8196
Type: SSH_FXP_SETSTAT, Size: 82, Number: 8457
Type: SSH_FXP_STATUS, Size: 24, Number: 8457
File: "D:\Shared Data\ACT Database\Database\Pawtucket Report 12.10.03.rtf"
Copying "D:\Shared Data\ACT Database\Database\Pawtucket Report 12.10.03.rtf" to remote directory started.
Type: SSH_FXP_OPEN, Size: 98, Number: 8707
Type: SSH_FXP_HANDLE, Size: 13, Number: 8707
Type: SSH_FXP_WRITE, Size: 4121, Number: 8966
11 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
Type: SSH_FXP_CLOSE, Size: 13, Number: 10500
Type: SSH_FXP_STATUS, Size: 24, Number: 10500
Type: SSH_FXP_SETSTAT, Size: 102, Number: 10761
Type: SSH_FXP_STATUS, Size: 24, Number: 10761
File: "D:\Shared Data\ACT Database\Database\Pawtucket Report 1.6.03.rtf"
Copying "D:\Shared Data\ACT Database\Database\Pawtucket Report 1.6.03.rtf" to remote directory started.
Type: SSH_FXP_OPEN, Size: 96, Number: 11011
Type: SSH_FXP_HANDLE, Size: 13, Number: 11011
Type: SSH_FXP_WRITE, Size: 4121, Number: 11270
Type: SSH_FXP_CLOSE, Size: 13, Number: 11780
Type: SSH_FXP_STATUS, Size: 24, Number: 11780
Type: SSH_FXP_SETSTAT, Size: 100, Number: 12041
Type: SSH_FXP_STATUS, Size: 24, Number: 12041
File: "D:\Shared Data\ACT Database\Database\Martingale Report 1.16.04.rtf"
Copying "D:\Shared Data\ACT Database\Database\Martingale Report 1.16.04.rtf" to remote directory started.
Type: SSH_FXP_OPEN, Size: 98, Number: 12291
Type: SSH_FXP_HANDLE, Size: 13, Number: 12291
Type: SSH_FXP_WRITE, Size: 3434, Number: 12550
Type: SSH_FXP_CLOSE, Size: 13, Number: 12804
Type: SSH_FXP_STATUS, Size: 24, Number: 12804
Type: SSH_FXP_SETSTAT, Size: 102, Number: 13065
Type: SSH_FXP_STATUS, Size: 24, Number: 13065
File: "D:\Shared Data\ACT Database\Database\M&A Services.tl2"
Copying "D:\Shared Data\ACT Database\Database\M&A Services.tl2" to remote directory started.
Type: SSH_FXP_OPEN, Size: 85, Number: 13315
Type: SSH_FXP_HANDLE, Size: 13, Number: 13315
Type: SSH_FXP_CLOSE, Size: 13, Number: 13572
Type: SSH_FXP_STATUS, Size: 24, Number: 13572
Type: SSH_FXP_SETSTAT, Size: 89, Number: 13833
Type: SSH_FXP_STATUS, Size: 24, Number: 13833
File: "D:\Shared Data\ACT Database\Database\M&A Services.tdx"
(ExtException)
Asking user:
Can't open file 'D:\Shared Data\ACT Database\Database\M&A Services.tdx'. ()
(EScpSkipFile) Can't open file 'D:\Shared Data\ACT Database\Database\M&A Services.tdx'.
File: "D:\Shared Data\ACT Database\Database\M&A Services.tdb"
(ExtException)
Asking user:
Can't open file 'D:\Shared Data\ACT Database\Database\M&A Services.tdb'. ()
(EScpSkipFile) Can't open file 'D:\Shared Data\ACT Database\Database\M&A Services.tdb'.
File: "D:\Shared Data\ACT Database\Database\M&A Services.sdx"
(ExtException)
Asking user:
Can't open file 'D:\Shared Data\ACT Database\Database\M&A Services.sdx'. ()
(EScpSkipFile) Can't open file 'D:\Shared Data\ACT Database\Database\M&A Services.sdx'.
Listing directory "/store/M&AStorage/Shared Data/ACT Database/Database".
Type: SSH_FXP_OPENDIR, Size: 60, Number: 14091
Type: SSH_FXP_HANDLE, Size: 13, Number: 14091
Type: SSH_FXP_READDIR, Size: 13, Number: 14348
Type: SSH_FXP_NAME, Size: 1293, Number: 14348
Type: SSH_FXP_READDIR, Size: 13, Number: 14604
Type: SSH_FXP_STATUS, Size: 28, Number: 14604
Status/error code: 1
Type: SSH_FXP_CLOSE, Size: 13, Number: 14852
Type: SSH_FXP_STATUS, Size: 24, Number: 14852
I hope you can suggest ways to acomplish this. Thanks, Jeff
Either you do not have permissions to read/access the source file or the file is locked by another application.
"11 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets"
If I see this line after attempting to transfer files (not folders as in your case) can I assume that absolutely no data was transmitted and the transfer should be attempted a second time?
Thanks in advance for any help!
That only means what 11 packets were not included in the log.
