'Cannot open file' err msg when rung from command line
nexar
I have the following simple script:
option batch abort
open pdgtt
put readme /home/purvez
This is saved in a file called winscptest.txt and is sitting in the same directory where winscp.exe is saved. When I run the following command line from that directory I get an error message saying: 'Cannot open file winscptest.txt'
winscp.com /script=winscptest.txt
I have also tried the following command but the same effect:
winscp.com /script=.\winscptest.txt
I'm running winSCP ver 4.3.6 on windows xp.
Anybody got any ideas of what could be the problem here?
I can run winscp.exe with a stored_session name from the command line and that works although I have to manually enter a password. Seems like the stored session does not retain the password.
Thanks in advance for all help/advice.
Purvez
nexar
:oops: MEGA EMBARRASSED !! Can't spell. The file name was sitting as wnscptest.txt (without the 'i')!!
However some help regarding the non-saving of the password would still help.
SORRY ALL!!
Purvez
