Can authenticate but 0 kb empty file or .filepart on server
dduplicki
This process was working without issue for several months but two days ago I can no longer post to our clients sftp server...I can authenticate...but but I either get a .filepart extension of the file if I try to send .pdf (.pdf log below) or in the case of a .txt file (.txt log below) I see the file on clients server but it is always 0 kb with empty contents...A similar issue happened when I tried to connect to their server via ipswitch months ago but I switched to WinSCP and WinSCP was able post and like I said had been posting fine for months...
Description: Log from .pdf file transfer
Description: Log from .txt file transfer
Re: Can authenticate but 0 kb empty file or .filepart on server
Can you check if there's any free disk space on the remote side?
