WinSCP, SSIS and SQL Job
jhong
I have the the executing of WinSCP as a Execute Process task in my SSIS project. Works perfectly as I have the WinSCP executable executing commands from a script file. Again works perfectly. However when I run the SSIS package from a SQL job I get the below error. Has anyone experienced this before or know what the issue is? Thanks in advance.
Description: In Executing "C:\Program Files (x86)\WinSCP\WinSCP.exe" "/script=D:\Success_Factors\SCP_Script\myscript.txt" at "", The process exit code was "1" while the expected was "0". End Error DTExec: The package execution returned DTSER_FAILURE (1). Started: 5:00:02 AM Finished: 5:00:05 AM Elapsed: 2.746 seconds. The package execution failed. The step failed.
twee
I still couldn't get it work please help.
Package works fine manually but failed in job scheduling with error The process exit code was "1" while the expected was "0"
So how do you export to INI file?
Thanks in advance.
TN
shrikanaskar1
SQL server Agent->Job cant run SSIS package with WINSCP command
I am using WinSCP as a Execute Process task in my SSIS project. Works fine in Visual Studio,however, when I run the SSIS package from a SQL job (SQL server Agent->Job) I get the an error. Appreciate any help.
option batch on
option confirm on
open sftp://user_name:password@ftp.xx.com:22 -hostkey = "ssh-rsa ....................."
cd /XYZ/TEST
close
I tried using INI file; It works in in Visual Studio but not in SQL Agent
Re: SQL server Agent->Job cant run SSIS package with WINSCP command
What "error"?
Did you read this? https://winscp.net/eng/docs/faq_scheduler
If the FAQ does not help, please attach a full session log file showing the problem (using the latest version of WinSCP).
