script fails without feedback
eflat
sac, ca
I'm launching my script from the command line like this:
"C:\Program Files\WinSCP\WinSCP.exe" /console /script=winscp-www.txt
And all I get is a flash of a window opening and closing. How can I tell what's happening?
If I start with winscp.com and enter in each line from my script file, they each run fine with no error or prompts. All I'm doing is connecting and getting one file.
Re: script fails without feedback
What if you run
"C:\Program Files\WinSCP\WinSCP.com" /script=winscp-www.txt
from cmd.exe console window?
eflat
sac, ca
Thanks...I see the following:
/$ "C:\Program Files\WinSCP\WinSCP.com" /script=winscp-www.txt
500 Unknown command.
What is "/$"? Looks like you are running WinSCP from *nix.
Can you posst your winscp-www.txt or WinSCP log file (use /log=logfilename switch).
