Exclude certain file on Synchronize
joeahn
Is there a way to exclude certain file when using synchronize. If yes, could you give me a simple example code.
3K
Geneva
Synchronize files from specified date stamp?
Is there a command to synchronize files starting from a specified date stamp? I would like to exclude files if their file's modified dates is before 1 Jan 2012.
Thanks.
3K
In Tracker Bug 672, the status is Fixed in: 5.0.6. Does it mean version 5.0.6? Is it possible to download this version and know the command to exclude by time stamp? Currently, in the download page, we can see 5.0.5 but not 5.0.6.
Thanks.
I have emailed you a link to development version of WinSCP.
Syntax file mask with timestamp is:
-filemask=<2012-02-01 00:00:00
3K
Geneva
Thanks a lot @Martin, got the development version. In my script below, if I wanted to synchronize documents posted >= 2012-01-01 00:00:00, where will I insert the command:
open ftp://username:password@ftpserver.itu.int
synchronize local C:\TEST\docs /docs
close
Thanks again.
Regards
3K
Geneva
Hi Martin,
I was trying to synchronize with filemask and include Word documents (*.doc*) only using the commands below, but it seems, it doesn't work:
option include=*.doc*
synchronize -filemask="<2012-02-01 00:00:00" local C:\TEST\docs /docs
synchronize -filemask="<2012-02-01 00:00:00" local C:\TEST\docs /docs -include="*.doc*"
Could you kindly help me.
Thank you.
The -filemask switch overrides include option (which is obsolete anyway with 5.0.6).
Also there's no -include switch.
The correct syntax is:
synchronize -filemask="*.doc*<2012-02-01 00:00:00" local C:\TEST\docs /docs
3K
Geneva
Thanks again, it works. That command filters Word doc with timestamp.
Another question, if I would like to include multiple filters, for example, Word (*.doc*) and Powerpoint (*.ppt*) files, what will be the command. I tried the command below, but it doesn't work.
synchronize -filemask="*.doc* *.ppt* <2012-02-01 00:00:00" local C:\TEST\docs /docs
Also, is it possible to have the new switch commands available for synchronize?
Many thanks for your excellent support.
Regards.
synchronize -filemask="*.doc*<2012-02-01; *.ppt*<2012-02-01" local C:\TEST\docs /docs
Do not understand.
3K
Geneva
Thank again :D , that command worked perfectly.
For my other question, is there a web page describing the new synchronize command, with examples? If there is none yet, it's ok.
Regards.
Torsten
Copenhagen
OPTION EXCLUDE with strange results for hidden UNIX files
I tried to use the exclude option to exclude a file .protftpd.fifo because the file can for some reason not be transferred. The file is located on a NAS with Linux, where I have shared a folder via SMB. My script is otherwise working fine.
I use this syntax:
option exclude .proftpd.fifo
But the result is different from my expectation:
include         |.proftpd.fifo
Comparing...
Local '\\backup\backup3\Old' => Remote '/Old'
Synchronizing...
Local '\\backup\backup3' => Remote '/'
\...\.proftpd.fifo        |            0 B |    0,0 KB/s | binary |   0%
(and then my script fails because of this file).
I have tried to "quote" the file name in quotation marks, no help.
What can I do to exclude the file?
Torsten
Re: OPTION EXCLUDE with strange results for hidden UNIX files
@Torsten: Please attach a full session log file showing the problem (using the latest version of WinSCP).
Torsten
Copenhagen
Hej Martin
Here we go.
First, as it looked on the command prompt. Note that it does not exclude the file .protftpd.fifo, the rest is secondary. Note further that the source folder \\backup\backup3\ is on an FTP server as well, but since WinSCP cannot copy directly from one FTP server to another, I had to share the folder on the source FTP server as an SMB share.
D:\Klinikdokumenter\Klinik - EDB\Klinik Backup\NAS Synchronization>"C:\Users\Administrator\AppData\Local\Programs\WinSCP\WinSCP.com"   /loglevel=2  /loglevel=2 /log=logfi
le.log /xmllog=logfile.xml  /script=glostrup-test2.txt
batch           on
reconnecttime   60
Connecting to fjernskrivebord.tg150.dk:8021 ...
Connected
Starting the session...
Session started.
Active session: [1] **********@fjernskrivebord.tg150.dk
Comparing...
Local '\\backup\backup3' => Remote '/Test'
Synchronizing...
Lost connection.
Could not retrieve file information
Can't get attributes of file '/Test/.proftpd.fifo'.
(A)bort, (R)econnect (0 s): Reconnect
Connected
Session started.
Lost connection.
(A)bort, (R)econnect (4 s): Abort
Lost connection.
Session 'backupuser@fjernskrivebord.tg150.dk' closed.
No session.
Exit code: 1
Max roundtrip: 5569
Second, the content of the script file here:
option batch on
option reconnecttime 60
open -passive=on  ftp://**********:***************@fjernskrivebord.tg150.dk:8021
synchronize -delete  -criteria=either  -transfer=binary  -resumesupport=on  remote  "\\backup\backup3\"   "/Test/"
Third, I attach the log file as requested. The interesting line is this one:
. 2020-05-14 01:08:29.219 Local file '\\backup\backup3\.proftpd.fifo' [2020-05-11T16:57:20.000Z] [0] included to synchronization
Fourth, I would like to mention that I found a workaround. As I noticed that the mysterious file is located in the FTP root folder, I simply moved my entire lot into a subfolder so that the hidden file is no longer in the way.
Good luck.
/Torsten
Description: XML log file
Description: Log file with log level 2
Thanks for all the details. Isn't the .proftpd.fifo actually a folder, not a file?
Torsten
You are right, it is a folder.
Do you mean to say I should use another exclude filter then? Which one?
/T
Hej Martin,
it works like a charm.
So, given the following folder structure:
 Directory of \\backup\backup3
11-05-2020  18:53    <DIR>          .
11-05-2020  12:13    <DIR>          ..
11-05-2020  18:57    <DIR>          .proftpd.fifo
14-05-2020  20:35    <DIR>          Daily Backups
11-05-2020  12:18    <DIR>          Old Backups
11-05-2020  12:37    <DIR>          Test
I have two possibilities now:
synchronize  -filemask=|.proftpd.fifo/;"Old Backups/";"Test/"  remote  "\\backup\backup3\"   "/Daily Backups/"
vs.
synchronize  remote   "\\backup\backup3\Daily Backups\"   "/Daily Backups/"
Where the former uses the file mask to exclude the unwanted ones, and the latter uses the source folder to only include the wanted.
Thank you!
/Torsten
