Error getting name of current remote directory: WinServ2008
fi5ly
when I access the Windows Server 2008 R2 Standard using WinSCP I get the following error, what should I do when this error occurred.
Cannot get real path for '.'.
Error code: 4
Error message from server: Failure
Request code: 16
and I get an error like this anymore.
Error listing directory ".
Bad message (badly formatted packet or protocol incompatibility).
Error code: 5
Error message from server: Bad message
Request code: 11
I am trying to use putty may be the same error when I use WinSCP but putty there are no problems with this error.
Using WinSCP 4.3.6 (Build 1655) on Windows 7 Ultimate Service Pack 1
fi5ly
Re: Error getting name of current remote directory: WinServ2008
What is your SSH/SFTP server?
I use freeSSHD ver 1.2.4
freeSSHD
Users Shell SFTP Tunnel
name ok ok -
Listen address 0.0.0.0 (All interfaces)
Port 22224
Windows Firewall with Advanced Security
Rule type: Port
Protocol and Ports: TCP
Specific local ports: 22224
Action: Allow the connection
Profile: All rule
Remote port: All ports
please let me know if there is something wrong
Try to upgrade your server. I'm using the same server, just newer version and it is working.
fi5ly
Indonesia
I have upgraded the server to service pack 1, but I still get the same error :roll: :(
This is my server specs:
OS Name: Microsoft Windows Server 2008 R2 Standard 64-bit
Version: 6.1.7601 Service Pack 1 Build 7601
System Type: x64-based PC
please tell what should i do
Well, I've meant the SSH server software. Not Windows.
