Login dialog gets orphaned on disconnect when editor open
Using WinSCP 4.3.5 on Windows 7, standalone version, commander GUI. This has been a problem ever since I can remember.
If you have a couple of editor windows open, and experience a disconnect, WinSCP will pop up the login dialog. If you then switch between editor windows, the login window becomes hidden and inaccessible. None of the other windows (the main window & editor windows) are functional because the login window is forced to be active, but you cannot find or select the login window because it is hidden behind other windows. Only option at this point is force end WinSCP. This happens to me very frequently.
Re: Login dialog gets orphaned on disconnect when editor open
Thanks for your report. Can you please try this with 5.0.5 beta?
