Commander Interface in a top/bottom view
Box293
Newcastle, Australia
When using a widescreen monitor I would like to use WinSCP in a Top/Bottom view.
For example, with the program as it is right now, it is displayed as "two panels, left for local directory, right for remote directory".
I would like "top for local directory, bottom for remote directory". Even the choice of selecting which one is on the top and which one is on the bottom.
Cheers
Troy
Re: Commander Interface in a top/bottom view
Thanks for your suggestion. Actually you are the first one requesting this. Let's see if there are more people who finds this useful.
dtrowan
Australia
I have just had a user request for this feature. The old FTP software they used had the transfer windows on top of each other and that's what they're used to. I myself prefer side by side, but many end users prefer on top of each other.
Ok, will consider this.
