Bugg since version 3.3 (i think)
AW
Norton interface, selecting one local file (or remote) and then Ctrl-click another one making two files selected. Pressing F5 and always get "Format '%d' invalid or incompatible with argument"
As stated I get the same error when doing this to remote files trying to copy them to local disc.
This error first ocured when upgrading from 3.3 to 3.5, and still exists in 3.5.5.
Regards
AW
Re: Bugg since version 3.3 (i think)
What language version do you use? If you do not use English, does it help switching to English?
Please, let me know.
AW wrote:
I was using swedish, but as you said, if I switch to English it works fine.
Thanks for answer. I'll notify swedish translator to fix it.
There was a small bug with the translation file (%d should be %s). New translation has been uploaded to the WinSCP maintainer.
Tack för buggrapporten! :-)
René -- the swedish translator
