Delete Remote-Files automatically, which are older then xxx
thoath
please help me. I looked for a script-possibility to delete remote-files on a server, which are older than xxx-Days. The Numer xxx of days (modification time) I want to configure. Is it possible?
Thomas
thoath
Thanks Martin,
Too bad that there's no easier way. I was hoping that I can use the "rm" command in WinSCP-use with a time parameter.
Unfortunately, I'm not really able to use javascript. Therefore, I can not use the variant likely. Do you have an example in VBS.
Ciao
Thomas
Freitag
Freitag avatar
I don't have a unix server at hand, but you might be able to do it by setting up a remote command. View - Preferences - Commands - Add
Assuming your remote box is unix/Linux/OSX the following ought to work
find /path/to/your/dir/tree -atime +XXX -exec rm {}\;
Where XXX is the number of days older than which you want to delete the files.
You may need to use the -f argument with rm to avoid problems with it trying to run interactively.
This will DELETE files, test it manually in some safe directory first. find is recursive so it will also include directories below the one you indicate and I think it follows links.
thoath
Thanks for Your Help,
I find now an own version:
I wrote a windows-bat with 3 commands:
Step 1: Synchronisize the remote-Folder with a local mirror-Folder
Step 2: Start a VB-Script which evaluate the Fileinformation of Files in the local-Folder --> and write a remove-joblist-File for WinSCP
Step 3: Execute the remove-joblist-File with WinSCP
It works fine, but it is not realy elegant.
Best regards and have a nice Christmas
Thomas
cpezie
looks promising
I would like to use something like this except I want to remove any directories in the dir older then 7 days. So where you have -atime +XXX -exec rmdir -rf {}\ I need to know the syntax for days instead of time and what is the -XXX reference?
Thanks,
