using vbs to connect sftp and use "put" command
FrankT
Hi! I am new to to scripting and WinSCP. I need to create a script to connect to a ftp service and copy files to it. I've tied the following with no success. Please help!!!
Dim wshShell
Dim sftpcmd
Set wshShell = WScript.CreateObject("WScript.Shell")
sftpcmd = "winscp /console /command " & """open sftp://nstcn61:password@10.10.1.100 -hostkey= ssh-rsa 1024 XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX" & "put c:\sysaudit\*.*" & "close""" & " " & """exit"
wshShell.Run(sftpcmd),1,true
wscript.sleep(20000) 'wait for 20 seconds until sftp is done
Any help would be appreciated.
Re: using vbs to connect sftp and use "put" command
You have quotes all wrong. I do not know VBS, but I guess right format is:
sftpcmd = "winscp /console /command ""open sftp://nstcn61:password@10.10.1.100 -hostkey=""""ssh-rsa 1024 XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX"""""" ""put c:\sysaudit\*.*"" ""close"" ""exit"""
Read also:
https://winscp.net/eng/docs/commandline#syntax
Of course the XX:XX:XX... has to be replaces with actual fingerprint.
FrankT
Read also:
WOW!!! I love you, man!!! You just fixed a problem for me that has been a thorn in my side for days!!! Thank you, thank you, thank you!!!
FrankT
OK, I have one last problem with this script; In the console, I am getting the following msg.
"The server's host key was not found in the cache. You have no guarantee that the server is the computer you think it is......If you trust this host, press Yes. To connect without adding host key to the cache, press No. To abandon the connection press Cancel.
Continue connecting and add host key to the cache?
(Y)es, (N)o, C(a)ncel, (C)opy Key:
I need it to pass on the key automatically. Any insite on how to do this with the example you provided?
Thanks!!!
