ks
Donor - Joined:
- 89
- Moscow
Cyrillic locale
Is WinWCP capable of parsing output of 'ls -la' on a system with Cyrillic locale? That's when the first line of ls output says not 'total n' but 'итого n' (same in Russian) plus the word is UTF encoded?
ks
I guess if I check the "Clear national variables" option that will do the trick?
Site Admin -
- 43,071
- Prague, Czechia
Yes, it should.I guess if I check the "Clear national variables" option that will do the trick?
- Guest
Looks like something broken in "Clear national variables" option.
I try to connect to server with ru_RU.UTF-8 locale and can't see directory listing with error
"Unexpected directory listing line" where I can see, that timestamp of directory/files are in
national (cyrillic) letters. I try to reset locale in terminal window:
/usr/home/roman$ locale
LANG=ru_RU.UTF-8
LC_CTYPE="ru_RU.UTF-8"
LC_COLLATE="ru_RU.UTF-8"
LC_TIME="ru_RU.UTF-8"
LC_NUMERIC="ru_RU.UTF-8"
LC_MONETARY="ru_RU.UTF-8"
LC_MESSAGES="ru_RU.UTF-8"
LC_ALL=
/usr/home/roman$ setenv LANG en_US.UTF-8
LANG=en_US.UTF-8
LC_CTYPE="en_US.UTF-8"
LC_COLLATE="en_US.UTF-8"
LC_TIME="en_US.UTF-8"
LC_NUMERIC="en_US.UTF-8"
LC_MONETARY="en_US.UTF-8"
LC_MESSAGES="en_US.UTF-8"
LC_ALL=
After that I can see directory/files listing.
shell:
/usr/home/roman$ ps
PID TT STAT TIME COMMAND
73109 0 Ss+ 0:00,07 -csh (csh)
LANG=ru_RU.UTF-8
LC_ALL=
LANG=en_US.UTF-8
LC_ALL=
shell:
/usr/home/roman$ ps
Site Admin -
- 43,071
- Prague, Czechia
- Guest
Hello, Martin. Thanks for looking at this issue.
There is session log.
- Guest
Maybe this can help you understand problem:
roman@solution:~ % echo $PAGER
more
roman@solution:~ % unset PAGER
more
roman@solution:~ % setenv PAGER
roman@solution:~ %
more
more
roman@solution:~ %
Site Admin -
- 43,071
- Prague, Czechia
Do you suggest that theMaybe this can help you understand problem:
more
more
roman@solution:~ %
unset does not work on your server?
- Guest
Do you suggest that theunsetdoes not work on your server?
https://man.openbsd.org/csh
Variable substitution
The shell maintains a list of variables, each of which has as value a
list of zero or more words. The values of shell variables can be dis-
played and changed with the set and unset commands. The system main-
tains its own list of ``environment'' variables. These can be dis-
played and changed with printenv, setenv and unsetenv.
As I understand, LANG variable can be operated via setenv/unsetenv command only.
- Guest
Maybe just add new "Shell" type ("csh" as example), which will be use unsetenv for "Clear national variables" procedure?
Site Admin -
- 43,071
- Prague, Czechia
Well, actually you should use configure the bash for WinSCP sessions (if your default/preferred shell is not bash-compatible).Maybe just add new "Shell" type ("csh" as example), which will be use unsetenv for "Clear national variables" procedure?
https://winscp.net/eng/docs/requirements#scp
- Guest
The bash shell is recommended for working with WinSCP. If your default shell does not work with WinSCP, you can specify another shell. Typing the full path (e.g. /bin/bash or /usr/local/bin/bash) is recommended.
It develops that I can put any symbol as shell! So, "/bin/sh" works very well for me. Thanks for help, Martin!
