script help with key public key authentication
codywang
Dear Sir,
I have script is able to login by by using public key authentication as below. However, it doesn't execute anything afterward, such as 'cd INBOUND". Any Idea? I even tried to put before open
"C:\Program Files\WinSCP\"winscp.com /log=C:\Inetpub\ftproot\CSTCCxFTP\CSTCCBatch\ADP\DP\DP.log-%datestr%-%timestr%.log /command "option batch abort" "open CINCISTATEpPSSsftp@170.146.246.0" /hostkey ="ssh-rsa 1023 37:4a:1c:5e:5b:0f:14:ef:31:81:42:b6:d7:fc:c5:db" "cd INBOUND" "put dp.log"
Re: script help with key public key authentication
Should be:
"C:\Program Files\WinSCP\"winscp.com /log=C:\Inetpub\ftproot\CSTCCxFTP\CSTCCBatch\ADP\DP\DP.log-%datestr%-%timestr%.log /command "option batch abort" "option confirm off" "open -hostkey=""ssh-rsa 1023 37:4a:1c:5e:5b:0f:14:ef:31:81:42:b6:d7:fc:c5:db"" CINCISTATEpPSSsftp@170.146.246.0" "cd INBOUND" "put dp.log"
Freitag
Freitag avatar
Siamquer wrote:
How can I change this line?
This is referring to one part of a larger script file. Probably some big FOO.BAT
This is not part of teh connection attempt when running the GUI version, only command line version.
