"Invalid access to memory" after resuming from sleep
matt99
Australia
Winscp 5.05 (Build 1782)
If I have a WinSCP session open when the computer goes to sleep, I get "Invalid Access to Memory" when Windows resumes.
Alex, the Marrch Ca'at
The same problem - 5.0.5, Win7 Ultimate 32-bit, on hibernate
Good day to you. I'm having the same problem - after restoring from Hibernate mode, WinSCP dispalyes 2 or 3 "Invalid access to memory" messages then crashes. I'd be glad to provide you with any additional info, including debug logs from any debug build you provide, if you still need it. My email is alexsvetalena--(at)--mail--ru
Re: The same problem - 5.0.5, Win7 Ultimate 32-bit, on hibernate
I have sent you an email with link to a debug version.
BuggB
I'm getting "Invalid accesst to memory" errors not only after resuming, but it happens as well when you disconnect your connection (either turn off wifi or just plug off lan cable) and trying to reconnect after switching your connections back on. It happens with every version i tried. Really very annoying problem. I'm using Win7 32bit, I don't remember it happened when i was using WinXP.
Re: Invalid access to memory
mtylerb
Warburg, AB
I have gotten this same error. Either when I disconnect the Wi-Fi or resume from sleep mode. No hibernate on this laptop. I also have another bug, but I'll make a new post for that.
MrCoffee wrote:
I'm also getting the same error. Win7 64bit. 5.0.6 Build 2074
