Lauching app fails (PuTTy Fatal error, Out of Memory)
Paul
I have a Windows 2000 SP2 workstation and have connected to my Solaris box with Putty and teraterm via SSH across a firewall.
However, when I launch the WinSCP, after filling in the hostname (IP), username and password (port is left at 22) I get an error: as follows:
I have sufficent system memory (128 Mb) and it is not maxed out.
Any thoughts?
TIA
Re: Lauching app fails (PuTTy Fatal error, Out of Memory)
I suppose that you've tried WinSCP1. Please, try WinSCP2 instead.
eispeer
Ok, that works. But where is the difference between version 1 and 2?
Just the protocol from ssh?
Thanks,
Eispeer
I don't understand your question. What difference? You find it unusual that old version does not work in certain situation, while a new one works fine?
