Error decoding SFTP packet (9,4,9)
padi
malaysia
Hope admin can help me... I used latest version WinSCP... when I tried to drag @ transfer my file to switch 3com E5500EI. I get this error
Re: What was the solution?
@S. Ahmed: Thanks for your report.
manto
Re: Error decoding SFTP packet (22, 4, 22).
So it looks to be version issue
Basically we need to set the ‘Preferred SFTP protocol version’ to 3.
How to do this:
Edit the connection in WinSCP
Open the Advanced menu
Choose Advanced
This will bring up a new popup.
Under Environment click on SFTP.
Change ‘Preferred SFTP protocol version’ to 3
Save the changes.
@manto: What SFTP server are you connecting to?
Clément
Hello there, I'm pretty late on this but I got the same error too! "Error decoding SFTP packet (9, 4, 9)" can u provide a solution please? :)
@Clément: Please attach a full session log file showing the problem (using the latest version of WinSCP). Use Debug 2 log level.
Clement Feuillet
@martin
  • cfeuillet@172.24.212.53.log (97.55 KB, Private file)
Description: Here's the log file, thanks a lot :)
The server is violating SFTP specification.
Anyway, I've implemented a workaround:
Issue 2272 – Workaround for SFTP servers (Cisco) which omit message field from status response
Can you send me an email, so I can send you back a development version of WinSCP for testing? Please include a link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
