Unable to Download File using FTPS
kuniadude
Honolulu
I've tried using both WinSCP.exe and WinSCP.com 5.0.5 to download a file using FTPS but can't get it to work. I'm able to connect to the FTP server, but I can't download nor list any files on the FTP site. I did accept this FTP server's certificate by answering Yes the first time I connected to it. I'm running WinSCP on Windows XP.
(Note: I'm able to download that file on a linux box when I use lftp; however, I can no longer use that box and need to do this on a Windows box)
You're help would be greatly appreciated!
Here's what I tried using WinSCP.com
winscp> open ftps://userid:password@ftp.myhost.net -passive=on -explicitssl
Connecting to ftp.myhost.net ...
Connected with ftp.myhost.net, negotiating SSL connection...
SSL connection established. Waiting for welcome message...
Connected
Starting the session...
Reading remote directory...
Session started.
Active session: [1] userid@ftp.myhost.net
winscp> cd my_dir
/my_dir
winscp> get 20111114.FI1 c:\tmp\20111114.FI1
Connected
Session started.
Can't get attributes of file '20111114.FI1'.
Invalid access to memory
winscp>
Here's an automation script I tried doing the same thing and unable to download the file.
winscp.exe /console /script=c:\tmp\auto.txt /log=c:\tmp\winscp.log
auto.txt
open ftps://userid:password@ftp.myhost.net -explicitssl -passive=on
option transfer ascii
cd my_dir
close
And lastly, here's my log file from this exercise.
. 2011-11-16 10:44:00.788 --------------------------------------------------------------------------
. 2011-11-16 10:44:00.788 WinSCP Version 5.0.5 (Build 1782) (OS 5.1.2600 Service Pack 3)
. 2011-11-16 10:44:00.788 Configuration: HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\
. 2011-11-16 10:44:00.788 Local account: MY_DOM\myuserid
. 2011-11-16 10:44:00.788 Login time: Wednesday, November 16, 2011 10:44:00 AM
. 2011-11-16 10:44:00.788 Session name: userid@ftp.myhost.net (Modified stored session)
. 2011-11-16 10:44:00.788 Host name: ftp.myhost.net (Port: 21)
. 2011-11-16 10:44:00.788 User name: userid (Password: Yes, Key file: No)
. 2011-11-16 10:44:00.788 Tunnel: No
. 2011-11-16 10:44:00.788 Transfer Protocol: FTP
. 2011-11-16 10:44:00.788 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2011-11-16 10:44:00.788 Proxy: none
. 2011-11-16 10:44:00.788 FTP: FTPS: Explicit SSL; Passive: Yes [Force IP: No]
. 2011-11-16 10:44:00.788 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2011-11-16 10:44:00.788 Cache directory changes: Yes, Permanent: Yes
. 2011-11-16 10:44:00.788 DST mode: 1
. 2011-11-16 10:44:00.788 Connecting to ftp.myhost.net ...
. 2011-11-16 10:44:00.882 Connected with ftp.myhost.net, negotiating SSL connection...
< 2011-11-16 10:44:00.975 220 EFT Server 6.3.8 Build 07.18.2011.2
> 2011-11-16 10:44:00.975 AUTH SSL
< 2011-11-16 10:44:01.069 234 AUTH Command OK. Initializing SSL connection.
. 2011-11-16 10:44:01.382 SSL connection established. Waiting for welcome message...
> 2011-11-16 10:44:01.382 USER userid
< 2011-11-16 10:44:01.460 331 Password required for userid.
> 2011-11-16 10:44:01.460 PASS ********
< 2011-11-16 10:44:01.553 230 Login OK. Proceed.
> 2011-11-16 10:44:01.553 SYST
< 2011-11-16 10:44:01.632 215 UNIX Type: L8
> 2011-11-16 10:44:01.632 FEAT
< 2011-11-16 10:44:01.725 211-Features supported:
< 2011-11-16 10:44:01.725  COMB target;source_list
< 2011-11-16 10:44:01.725  REST STREAM
< 2011-11-16 10:44:01.725  SIZE
< 2011-11-16 10:44:01.725  MDTM
< 2011-11-16 10:44:01.725  XCRC filename;start;end
< 2011-11-16 10:44:01.725  SSCN
< 2011-11-16 10:44:01.725  MLST Size*;Modify*;Create;Type*;Unique;Perm*;Lang;Media-Type;CharSet;
< 2011-11-16 10:44:01.725  XNOP
< 2011-11-16 10:44:01.725 211 END
> 2011-11-16 10:44:01.725 PBSZ 0
< 2011-11-16 10:44:01.803 200 PBSZ Command OK. Protection buffer size set to 0.
> 2011-11-16 10:44:01.803 PROT P
< 2011-11-16 10:44:01.897 200 PROT Command OK. Using Private data connection
. 2011-11-16 10:44:01.897 Connected
. 2011-11-16 10:44:01.897 --------------------------------------------------------------------------
. 2011-11-16 10:44:01.897 Using FTP protocol.
. 2011-11-16 10:44:01.897 Doing startup conversation with host.
> 2011-11-16 10:44:01.897 PWD
< 2011-11-16 10:44:01.975 257 "/" is current folder.
. 2011-11-16 10:44:01.975 Getting current directory name.
. 2011-11-16 10:44:01.975 Startup conversation with host finished.
< 2011-11-16 10:44:01.975 Script: Active session: [1] userid@ftp.myhost.net
> 2011-11-16 10:44:01.991 Script: option transfer ascii
< 2011-11-16 10:44:01.991 Script: transfer        ascii
> 2011-11-16 10:44:01.991 Script: cd my_dir
. 2011-11-16 10:44:01.991 Changing directory to "my_dir".
> 2011-11-16 10:44:01.991 CWD my_dir
< 2011-11-16 10:44:02.069 250 Folder changed to "/my_dir".
. 2011-11-16 10:44:02.069 Getting current directory name.
> 2011-11-16 10:44:02.069 PWD
< 2011-11-16 10:44:02.163 257 "/my_dir" is current folder.
< 2011-11-16 10:44:02.163 Script: /my_dir
> 2011-11-16 10:44:02.163 Script: get 20111114.FI1 c:\tmp\20111114.FI1
. 2011-11-16 10:44:02.163 Listing file "20111114.FI1".
. 2011-11-16 10:44:02.163 Retrieving directory listing...
> 2011-11-16 10:44:02.163 TYPE A
< 2011-11-16 10:44:02.257 200 Type set to A.
> 2011-11-16 10:44:02.257 PASV
< 2011-11-16 10:44:02.335 227 Entering Passive Mode (12,129,26,30,117,48).
> 2011-11-16 10:44:02.335 LIST -a
< 2011-11-16 10:44:02.428 150 Opening ASCII mode data connection for file list.
. 2011-11-16 10:44:17.788 Timeout detected.
. 2011-11-16 10:44:17.788 Could not retrieve directory listing
< 2011-11-16 10:44:17.788 Script: Connecting to ftp.myhost.net ...
. 2011-11-16 10:44:17.788 Connecting to ftp.myhost.net ...
< 2011-11-16 10:44:17.866 Script: Connected with ftp.myhost.net, negotiating SSL connection...
. 2011-11-16 10:44:17.866 Connected with ftp.myhost.net, negotiating SSL connection...
< 2011-11-16 10:44:17.959 220 EFT Server 6.3.8 Build 07.18.2011.2
> 2011-11-16 10:44:17.959 AUTH SSL
< 2011-11-16 10:44:18.053 234 AUTH Command OK. Initializing SSL connection.
< 2011-11-16 10:44:18.241 Script: SSL connection established. Waiting for welcome message...
. 2011-11-16 10:44:18.241 SSL connection established. Waiting for welcome message...
> 2011-11-16 10:44:18.241 USER userid
< 2011-11-16 10:44:18.334 331 Password required for userid.
> 2011-11-16 10:44:18.334 PASS ********
< 2011-11-16 10:44:18.444 230 Login OK. Proceed.
> 2011-11-16 10:44:18.444 SYST
< 2011-11-16 10:44:18.538 215 UNIX Type: L8
> 2011-11-16 10:44:18.538 FEAT
< 2011-11-16 10:44:18.616 211-Features supported:
< 2011-11-16 10:44:18.616  COMB target;source_list
< 2011-11-16 10:44:18.616  REST STREAM
< 2011-11-16 10:44:18.616  SIZE
< 2011-11-16 10:44:18.616  MDTM
< 2011-11-16 10:44:18.616  XCRC filename;start;end
< 2011-11-16 10:44:18.616  SSCN
< 2011-11-16 10:44:18.616  MLST Size*;Modify*;Create;Type*;Unique;Perm*;Lang;Media-Type;CharSet;
< 2011-11-16 10:44:18.616  XNOP
< 2011-11-16 10:44:18.616 211 END
> 2011-11-16 10:44:18.616 PBSZ 0
< 2011-11-16 10:44:18.709 200 PBSZ Command OK. Protection buffer size set to 0.
> 2011-11-16 10:44:18.709 PROT P
< 2011-11-16 10:44:18.803 200 PROT Command OK. Using Private data connection
< 2011-11-16 10:44:18.803 Script: Connected
. 2011-11-16 10:44:18.803 Connected
. 2011-11-16 10:44:18.803 Doing startup conversation with host.
< 2011-11-16 10:44:18.803 Script: Starting the session...
> 2011-11-16 10:44:18.803 PWD
< 2011-11-16 10:44:18.881 257 "/" is current folder.
< 2011-11-16 10:44:18.881 Script: Reading remote directory...
. 2011-11-16 10:44:18.881 Changing directory to "/my_dir".
> 2011-11-16 10:44:18.881 CWD /my_dir
< 2011-11-16 10:44:18.991 250 Folder changed to "/my_dir".
. 2011-11-16 10:44:18.991 Getting current directory name.
> 2011-11-16 10:44:18.991 PWD
< 2011-11-16 10:44:19.069 257 "/my_dir" is current folder.
. 2011-11-16 10:44:19.069 Startup conversation with host finished.
< 2011-11-16 10:44:19.069 Script: Session started.
kuniadude
Re: Unable to Download File using FTPS
Thank you Martin. I ran your debug version and emailed you the trace log. I hope you can resolve my FTPS download problem!
Re: What was the resolution to this?
JLCapson wrote:
I'm getting the same problem, what was the fix?
