Delete files obsolete with keepuptodate
Ivo
For synchronize client and server I use /keepuptodate with a script.
Perfect but when I delete file from client WinSCP don't delete file from server.
Anyone have a idea?
Tanks
Ghosti1337
I use a script with keepuptodate for continuous monitoring on FTP remote folder. Uploading works as intended. However when I delete a file on the local folder, it should delete it on the remote folder as well. I use -delete in my script, but it doesn't work. Whats wrong with it? This is my script:
option batch on
open ftpes://xxxxxxxxxxxxxxx:xxxxxxxxxxxx@xxxxxxxxxx/
keepuptodate -delete X:\LOCALFOLDER /REMOTEFOLDER
@Ghosti1337: I've just test it and it works for me.
Make sure you specify name of the file you have deleted and the exact time you did so.
