WINSCP compatible with Win7 64 bit
EddyP001
hi all,
currently im running with Version 3.8.2 (build 330) on Win XP pro (sp3) 32 bit and i want to know of this one is also working on Win7 64 bit.
Is there a list with winscp version that are working on Win7 64 bit ?
thanks in advance, Eddy
Re: WINSCP compatible with Win7 64 bit
3.8.2 should be working on Windows 7. But you are strongly encouradged to upgrade to the latest stable version.
Priyanka
Is WinSCP 5.1.4 compatible with Windows 7 64-bit?
Thanks.
petervot
Yes, it is.
(Altough winscp 5.5 keeps freezing after about 1 minute of inactivity with the remote server. Reconnection pop up windows appears. Annoying bug, since v5.1.x)
petervot wrote:
Yes, it is.
