put <folder> subdir problem
lony
I try to upload an folder (Zend Framework) but instead of copying the hole structure WinSCP is only copying the source file in the last subdirectory to the actual remote folder.
The script is basic:
option transfer binary
open foo@xtf
cd library
rmdir My
put library\My\
The result and also the folder structure is shown here:
/library
My
library\My | 0 KiB | 0,0 KiB/s | binary | 0%
library\My\View | 0 KiB | 0,0 KiB/s | binary | 0%
library\My\View\Helper | 0 KiB | 0,0 KiB/s | binary | 0%
AutoRefreshRewriter.php | 2 KiB | 0,0 KiB/s | binary | 100%
Any ideas how I can fix this problem?
Re: put <folder> subdir problem
lony
Thank you for your response.
I posted my Logfile under <invalid hyperlink removed by admin>.
Hopefully this could clarify thinks. Just to clear up the script as well, I posted it again.
open antftp@xdf
cd library
rmdir My
put library\My\
close
Thanks.
