Features for commander mode
pandronic
I thought of a few features that I think will make WinSCP a better filemanager:
- options to customize the colors and fonts: background and foreground for normal, selected, under cursor and selected under cursor; font face and size for the whole file list
- the possibility to connect to a server either on the left or the right panel, on none at all (just local files) or on both panels (to copy from server to server)
What do you think?
Re: Features for commander mode
WinSCP follows Windows scheme. I'm not big fan or per-application customizations. Anyway, you can change background color:
https://winscp.net/eng/docs/task_connections#session_color
Please read:
https://winscp.net/tracker/1893
https://winscp.net/eng/docs/faq_fxp
pandronic
Thanks for the reply. I understand your position. I'm actually using Far Manager, but I thought about investigating some alternatives.
Actually if I think about it I have a Far Manager question, but I'll post it in the appropriate forum :)
Keep up the good work
