Problem with SFTP and UTF8 encoding
JoeMue
Hello!
Support for utf8-encoding when using SFTP does not work. Although I set utf8-encoding for file names in the environment to yes, file names and directories are displayed wrong. German umlaute (ä, ö, ü) are displayed in their isolatin representation of the ut8 encoded string.
Example: Büro instead of Büro
This does not seem to be a server problem. All other clients I tried (and I tried them all... FileZilla, CoreFTP, SmartFTP, WS_FTP, ...) display these names correctly.
Jochen
Re: Problem with SFTP and UTF8 encoding
DonD
Germany, Cologne
Hello @all!
I'm new in here and I saw this topic during my attempt to solve the same Problem which is described in here.
I would be glad if someone could help me by giving me a solution.
Thank's a lot.
Greets DonD
DonD
Germany, Cologne
Hello Martin!
I'm using WinSCP 5.5.0,
Settings:
SFTP, if rejected, use FTP;
Language: German;
Default Encoding: UTF-8;
I've allready read the other options, but I didn't find any further Settings.
Thanks for your help.
There's no "SFTP, if rejected, use FTP" mode. So what protocol do you use, SFTP or FTP?
What value do you use for UTF-8 encoding for filenames?
DonD
Germany, Cologne
Sorry, i'm running late, but it's very busy in here...
I use SFTP and UTF-8.
But to give you some more information i've attached some files.
  • Unbenannt2.JPG (56.33 KB, Private file)
Description: Encoding
  • Unbenannt.JPG (41.52 KB, Private file)
Description: Session and Connection
