Plugin for Total/Windows Commander
mastabog
If you don't already know, Total Commander (formerly known as Windows Commander) is one of the most popular file managers. It says it's shareware but actually it asks you to press one key before starting it (no other limitations whatsoever) so you can see it as free software.
It would be GREAT if you could do a plugin for it as you did for FAR. There is a plugin for TC but badly written and no longer in development. The documentation for File System plugins of TC can be found here: https://www.ghisler.com/plugins.htm#filesys (last link in the File System plugins list).
Or maybe you can provide us with a compatible DLL so that we can implement ourselves a plugin for TC using your DLL.
Thanks anyway for WinSCP, great tool.
Cheers.
Re: Plugin for Total/Windows Commander
I know about Total Commander. I may implement plugin for it eventually. But I do not promise anything :-)
It could be really wonderful to implement plugin like this in Totalcmd.
It will be great to use only one aplication for almost everything about files and transfers ...
Many Thanks
chris.aw
A WinSCP-Plugin for Total Commander would not be nice... it would be great :!:
It's a really complete commander still under development...
Please! :wink:
Wurmi
I think many people would appreciate plugin for Total commander. As was already said, there is a simple sftp plugin, but it lacks on features and it doesn't support scp protocol. :?
:idea: You could put it as a poll question on your page and see the response
thanks
Wurmi 8)
"drzim palce"
Wurmi wrote:
You could put it as a poll question on your page and see the response :wink:
OK, next time I will :-)
Michael
Hello Martin,
why in detail you are not interesting in developing a WinSCP based SCP/SFTP plugin for TotalCommander? I know it is not very funny to add plugins for every file manager and it could be a lot of work, but TotalCommander has a big and great Community which would thank you very much if you could add such a plugin.
Greetings,
Michael
Michael wrote:
why in detail you are not interesting in developing a WinSCP based SCP/SFTP plugin for TotalCommander? I know it is not very funny to add plugins for every filema nager and it could be a lot of work, but TotalCommander has a big and great Community which would thank you very much if you could add such a plugin.
Well, I do not like Total Commander. I has ugly and non-intuitive user interface. Whenever I have to use it, I'm not able to find function I need. I know that it is just personal that many people are satisfied with it. But I'm not.
I understand, I also do not have any motivation to develop extensions for apps I do not like.
It has ugly user interface.
Well, that's true...
but I use it now for years and so I like many things of it. Maybe I'll find time someday to write a WinSCP based extension...
Greetings,
Michael
Subscribe to this )
It would be REALLY nice if someone could develop such plugin.
Martin Dzubak
plugin to total commander or TABS ;-)
My question is: is difficult to develop support for tabs? like in total commander...
I'll press CTRL+T so I can switch between two connections or between two locations in box... or etc...
Thanks for your answer, also for tabs in WinSCP or Total Commander plugin..... ;-)
3 Topics with more than 2600 views since 2004.
I think, that's an argument. That shows imho, that there exists a large interest after a Plugin.
You can make yourself an individual menu and icons or you load appropriate from the Web. Then it looks modern and than you are able to find all functions you need.
So that the appearance is not necessarily a counterargument.
But it is your decision, but it would be nice, if you would consider it again.
Jaeys
solus
Was looking for winscp-plugin for Total Commander and came to that page... I wouldn't say that user interface of tcmd is uglier than far's, and I'm 100% sure, that it (I mean tcmd's ui) is much more practic and convenient. Anyway, it's just my opinion, but again, I'm sure, that number of tcmd-users is much greater than that of far. It would be really cool to have this plugin for tcmd.
@solus: I've never said that FAR had better UI then TC. I just personally prefer FAR. I have developed the FAR plugin for myself and just made it available to public.
guest
Re: We want WinSCP plugin for Total Commander!
bread and circuses!
mitnlag
About Console Mode
When starting winscp from .bat file it creates new window, takes focus and other... Can WinSCP start without creating console window and use current?
Re: About Console Mode
Winscp3.exe being GUI application cannot inherit the console of parent process. You need to use winscp3.com instead.
Bjorn Wennerstrom
Here's another Total Commander addict that's missing the SCP feature.
It's pretty clear from this thread that @martin won't be doing this, but since WinSCP is open-source, anyone of us could do it! Time to start pitching in donations to someone? It's up for grabs guys :-)
Tofu
SCP plugin for TotalCommander
Do we have any free and opensource windows compiler/environment so we can build this plugin under this environment? If FAR plugin exists and WinSCP is opensource it shoudn't be so hard to create this SCP plugin for TotalCommander... Somebody has to start, enough is enough... :shock:
Hi, Firstly I must say that WinSCP is a great peace of software... and as many others have stated I myself would also see a Total Commander plug-in. With regards to the above mentioned statement, I must just give my 10 cents worth on the subject. I've been really studying WinSCP and it's configs... and I must say for someone that doesn't really like the Total CMD interface have made the WinSCP's one look a lot the same as the Total CMD's one....
But on another matter, is it possible to get hold of the code for the plugin for salamander? I would like to see not just how it looks but also how it was written. I've been out of coding for a long time but would like to see if maybe and this is a BIG maybe I would be able to through a plugin together for TotalCMD...
But again thx
I have not meant the concept of GUI. It is the same. I've meant how it looks. But if you do not see the difference youself, I guess I cannot explain it.
But on another matter, is it possible to get hold of the code for the plugin for salamander? I would like to see not just how it looks but also how it was written. I've been out of coding for a long time but would like to see if maybe and this is a BIG maybe I would be able to through a pulugin togeter for TotalCMD...
Let's discuss this over email.
And here is another guy who really would like to have WinSCP as a TC-plugin.
Maybe the looks aren't the strenght of TC, functionaliy and WOW are. Personally I evaluated also Altap Salamander who's looks are better but WOW (IMHO) not.
Any news about the chances for a TC-plugin ?
Thanks (for the great WinSCP)
What do you miss in Altap Salamander?
Not yet ;-)
Guest Jan
What do I miss in AS (now in version 2.51)?
What doy ou miss in Altap Salamander?
The top show stoppers for me (a licensed owner of both TC and AS)
# 1
Unicode support (even if there are only a few Cyrillic-based file names in my documents from my work in the Balkans, it is a problem)
# 2
Synchronize function for folders
# 3:
7-zip (new version) plugin support, especially for encrypted archives (AES)
Other:
- background operations for archives
- 64-bit version
- full Vista (UAC) support
Jan
Re: What do I miss in AS (now in version 2.51)?
Guest Jan wrote:
...Altap Salamander?
...or Total Commander?
A really useful feature from Total Commander as far as I'm concerned is the ability to filter selected files using a pattern-matching string (like regex).
TC_lava
Total Commander
I love the built-in viewer (F3) of Total Commander.
It's fast, and you can search in it - both backward AND forward, which is handy when you're reading logfiles.
I've used winscp for a few days - what I mist most is the familiarity with the TC GUI, F3 (view) and the backwards search in view/edit.
I'm also begging for a T.C. plugin!
eyedmax
Issue 231 – Plugin to Total Commander
Shit. Now it became a bug!!!
For now I'm waiting for you to change your mind about TC plugin for four years, and seems like counting....
BTW For now I use SCP for three years - and thank for your work!!!
:D
arky
PL
@eyedmax, @martin: like he wrote, add it as a issue - shame that with so low priority :( I'm also waiting years for this plugin to TC, WinSCP is a very good tool, but I hate using thousands of separate tools for each task...
IMHO when plugin became available finally number of WinSCP users will drop dramatically, maybe that's a reason for such delay?
Why should I care if people use WinSCP or WinSCP plugin for TC? In fact number of WinSCP users would probably increase dramatically with WinSCP plugin for TC.
DarkKnight
You would save my day
Greeting! I'm one of those guys out there who found you side because I need a TC SCP PlugIn. Would be great if you find the time for at least a first version ... Thanks a lot! DK
Robertus
Vote for TC-plugin
I really really want that plugin too.
you should set up a paypal-donate button and tell us ho much money its takes to MAKE you do it
theHansson
Another vote
Just adding another vote for TC plugin.
If there was a donate button dedicated to this effort, I'd click it. Maybe even twice :wink:
JA
Paypal donation for WINSCP plugin for Total commander
I think it is a great idea, I will donate as well!!!
Martin - please do it.
janmanzer411
Arkansas USA
Re: Another vote
Oh, there's your motivation.
+1 vote for the plugin.
_________________
Best Regards,
Jan Manzer
Old Command Line User
Please turn on your brain.
Plug in for Salamander is NOT free.
TC and Salamander are competitor.
WinSCP have some affinity ( just my opinion) with Altap.
So it's not a priority to define a plug-in for TC.
Just a commercial agreement or not ?!
DredSFTP is working fine and without OpenCandy.
DredSFTP is also free.
Don't waste your time.
Does this much talked-about PlugIn REALLY exist?
regards
Will
PS : I used TC and Salamander. I still use TC.
One is more expensive regardless of existing Plug-Ins.
I use command line for almost all my work, and TC with some useful Plug In for some tasks (with a Licence of course).
