Is it possible
CT
Is it possible
Is ist possible with WinSCP connect with 2 server on the same time ? I want copy something from one server to the other server with WinSCP. Sorry for my bad english, i come from germany ;)
CT
Know you a Prog ?
Know you a programm what can it ? I Try ist with FlashFXP and Total Coammnder but the cannot use Protocol SCP / SFTP.
Re: Know you a Prog ?
It depends on how do you want to do it. If you want directly transfer files from one server to the other, than SFTP does not allow this. With SCP it may be done, but I do not know any GUI tool that can do it.
If you want to download the files to local drive (maybe to temporary folder) and then upload them to the second server, you can drag&drop files between two instances of WinSCP.
CT
Hmm
If i try to to copy from 1 WinSCP to a second WinSCP it failed. I want to do this, because we have 2 Root Server and i want to copy soemthing and its faster. I dont want to copy it to my HD and then do the upload, its to slow. Sorry for ma english, i am a german :)
Re: Hmm
WinSCP cannot do this, sorry :-(
