protocol sftp
guest 111
protocol sftp
I get an error message when trying to connect to a host- they say they have sftp for protocol but the error message says they dont't have sftp-- how can I connect to them with sftp protocol
Re: protocol sftp
Common confusion is SFTP vs FTPS. Make sure you are not supposed to use FTPS.
If it is really SFTP, please post a full log file showing the problem.
