Unable to list files larger 2GB
Sammy
WinSCP is unable to list files larger than 2GB. I have running sshd and connect using SCP protocol. The file is on ext3 filesystem if that matters. I am using BASH on the running sshd host
I tried it on WinSCP 5.0.2 and 4.3.1.
Re: Unable to list files larger 2GB
I believe it is server-side problem. If you do not, please post a full log file showing the problem.
