Script Synchronization
I am trying to sync my server files to a local PC but keep getting "Nothing to synchronize" Where am I going wrong?
# Automatically answer all prompts negatively not to stall
# the script on errors
option batch on
# Exclude files that I don't care about
# option exclude "*.db; *.ini; *.tmp;"
# Connect to the server (replace with your username, password, domain)
open "eaglerising (LAN)"
# Do the work
synchronize local -mirror -delete -nopermissions f:\server-backup\file-backup /HDD-1000-1
# Close and exit
close
Re: Script Synchronization
Can you list both directories before "synchronize" and post an output here?
lls f:\server-backup\file-backup
ls /HDD-1000-1
