Drag and Drop support for Session Folders
consistency
consistency avatar
austria
as mentionied in the subject, it would be quite handy to be able to drag and drop a folder in the stored session area.
currently only single sessions could be drag'n'droped.
Re: Drag and Drop support for Session Folders
Well WinSCP supports only single-level session folder hierarchy and folders are alphabeticaly sorted. So there's no point of supporting drag&drop. What do you actually want to achieve? Multi-level folders or custom ordering of the folders? Or something else?
consistency
consistency avatar
austria
not sure what you mean with "single-level session folder hierachy", in my winscp i have multiple folder levels
this screenshot is taken from the regular winscp v 4.3.5
so as you see in the image, i would like to drag and drop the whole customer folder (with all its subfolders and sessions) in the third folder. in the current version it is only possible to recreate all folders and subfolder in the target folder and then drag and drop each saved session one by one.
it would be great if i just can drag the whole folder.
btw. it also would be great to have the feature of selecting multiple folders and sessions like in the windows explorer.
consistency
consistency avatar
austria
thank you for adding to the bug tracker.
https://winscp.net/tracker/424
this would also be a feature which would be cool but i does not meant it.
my feature request was, beeing able to _select_ multiple folders or sessions or a mix of both of them, so they can be drag and droped together. right now you can only drag the sessions one by one to a different folder. it would be cool to be able if i can select sessions (like files in explorer) and folders (like folders in explorer) the same way as in the filemanager. holding shift selects from selected session/folder to the next click, holding ctrl selects single sessions or directories.
do you know what i mean? if not just tell, then i provide a screenshot
OK, understood.
