script fails with return code 0
tperk
Using WinSCP 4.3.5 (Build 1463) on Windows XP SP3. I'm using the command line version.
WinSCP can falsely detect errors in the call command when the return code is 0. If the return code 0, then there should be no error. This is demonstrated below:
winscp> option echo off
echo            off
winscp> option bat abort
batch           abort
winscp> option confirm off
confirm         off
winscp> option transfer automatic
transfer        automatic
winscp> open -timeout=1 root:FM@192.168.101.2
Searching for host...
Connecting to host...
Authenticating...
Using username \"root\".
Authenticated.
Starting the session...
Reading remote directory...
Session started.
Active session: [1] root@192.168.101.2
winscp> call echo "asdf" >&2
Authenticating...
Authenticated.
Session started.
asdf
Command 'echo "asdf" >&2'
failed with return code 0 and error message
asdf.
This doesn't happen if I use stdout instead of stderr. So I'm guessing WinSCP is checking stderr when it should only be checking the return code.
Keep up the good work, your software is really useful! Thank you.
Re: script fails with return code 0
Well, I believe it is perfectly correct to check the error output. And you can always wouraround that the way you did (by redirecting to stardard output).
tperk
I agree that most programs only write to stderr when there is an error, but it is also common practice to write warnings to stderr. So I would argue that proper execution is indicated solely by the exit code.
Also for your consideration: what if you want to test the result of a command?
call if cmd1 ; then cmd2 ; fi
If cmd1 writes to stderr then the user needs to start putting redirects everywhere.
Maybe I'm being unreasonable, and I should put stuff like this in a bash script instead of writing one-liners. I was just expecting "option batch abort" to be analogous to "set -e".
Anyway, thank you Martin.
