4.3.5 Stored host name in Scripting
lravens19
Server: windows 2003R2 server sp2
Winscp: 4.3.5
Using scripting/automation
Script:
echo option batch abort > c:\windows\Harvardftp.txt
echo open HPHC >> c:\windows\Harvardftp.txt
echo cd 837/toHPHC >> c:\windows\Harvardftp.txt
echo put HPHC1425_HPHC142501_P_%year%%month%%day%_%nhour%%xminute%.837 >> c:\windows\Harvardftp.txt
echo bye >> c:\windows\Harvardftp.txt
When I run my script to connect to a stored session it will not connect to a stored session "HPHC". When I try to just double click on the stored session in the gui it connects fine. I compared both scripting log and gui log and noticed a difference. The "host name" is not carrying through in the script. You can see in the logs below that the scripted log tries to connect to a the host name which is really the session name. And the Gui connects to the actual host name. This was a fresh install of 4.3.5 on a new server.
Scripting/automated log:
. 2011-09-22 13:59:04.499 --------------------------------------------------------------------------
. 2011-09-22 13:59:04.499 WinSCP Version 4.3.5 (Build 1463) (OS 5.2.3790 Service Pack 2)
. 2011-09-22 13:59:04.499 Configuration: HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\
. 2011-09-22 13:59:04.499 Local account: NT_PROD\rmgsupp
. 2011-09-22 13:59:04.499 Login time: Thursday, September 22, 2011 1:59:04 PM
. 2011-09-22 13:59:04.499 Session name: HPHC (Ad-Hoc session)
. 2011-09-22 13:59:04.499 Host name: HPHC (Port: 22)
. 2011-09-22 13:59:04.499 User name: (Password: No, Key file: No)
. 2011-09-22 13:59:04.499 Tunnel: No
. 2011-09-22 13:59:04.499 Transfer Protocol: SFTP (SCP)
. 2011-09-22 13:59:04.499 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2011-09-22 13:59:04.499 Proxy: none
. 2011-09-22 13:59:04.499 SSH protocol version: 2; Compression: No
. 2011-09-22 13:59:04.499 Bypass authentication: No
. 2011-09-22 13:59:04.499 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2011-09-22 13:59:04.499 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2011-09-22 13:59:04.499 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2011-09-22 13:59:04.499 SFTP Bugs: -,-
. 2011-09-22 13:59:04.499 Return code variable: Autodetect; Lookup user groups: Yes
. 2011-09-22 13:59:04.499 Shell: default
. 2011-09-22 13:59:04.499 EOL: 0, UTF: 2
. 2011-09-22 13:59:04.499 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2011-09-22 13:59:04.499 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2011-09-22 13:59:04.499 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2011-09-22 13:59:04.499 Cache directory changes: Yes, Permanent: Yes
. 2011-09-22 13:59:04.499 DST mode: 1
. 2011-09-22 13:59:04.499 Looking up host "HPHC"
GUI Log:
. 2011-09-22 14:19:29.806 --------------------------------------------------------------------------
. 2011-09-22 14:19:29.806 WinSCP Version 4.3.5 (Build 1463) (OS 5.2.3790 Service Pack 2)
. 2011-09-22 14:19:29.806 Configuration: C:\Program Files (x86)\WinSCP\WinSCP.ini
. 2011-09-22 14:19:29.806 Local account: NT_PROD\rmgsupp
. 2011-09-22 14:19:29.806 Login time: Thursday, September 22, 2011 2:19:29 PM
. 2011-09-22 14:19:29.806 Session name: HPHC (Modified stored session)
. 2011-09-22 14:19:29.806 Host name: sftp.harvardpilgrim.org (Port: 22)
. 2011-09-22 14:19:29.806 User name: pfhp1425 (Password: Yes, Key file: No)
. 2011-09-22 14:19:29.806 Tunnel: No
. 2011-09-22 14:19:29.806 Transfer Protocol: SFTP (SCP)
. 2011-09-22 14:19:29.806 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2011-09-22 14:19:29.806 Proxy: none
. 2011-09-22 14:19:29.806 SSH protocol version: 2; Compression: No
. 2011-09-22 14:19:29.806 Bypass authentication: No
. 2011-09-22 14:19:29.806 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2011-09-22 14:19:29.806 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2011-09-22 14:19:29.806 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2011-09-22 14:19:29.806 SFTP Bugs: -,-
. 2011-09-22 14:19:29.806 Return code variable: Autodetect; Lookup user groups: Yes
. 2011-09-22 14:19:29.806 Shell: default
. 2011-09-22 14:19:29.806 EOL: 0, UTF: 2
. 2011-09-22 14:19:29.806 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2011-09-22 14:19:29.806 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2011-09-22 14:19:29.806 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2011-09-22 14:19:29.806 Cache directory changes: Yes, Permanent: Yes
. 2011-09-22 14:19:29.806 DST mode: 1
. 2011-09-22 14:19:29.821 Looking up host "sftp.harvardpilgrim.org"
. 2011-09-22 14:19:29.946 Connecting to 155.49.240.29 port 22
. 2011-09-22 14:19:30.040 Waiting for the server to continue with the initialisation
. 2011-09-22 14:19:30.040 Detected network event
. 2011-09-22 14:19:35.087 Detected network event
. 2011-09-22 14:19:35.087 Server version: SSH-2.0-4.1.5.6 SSH Secure Shell Windows NT Server
. 2011-09-22 14:19:35.087 We believe remote version has SSH-2 ignore bug
. 2011-09-22 14:19:35.087 Using SSH protocol version 2
. 2011-09-22 14:19:35.087 We claim version: SSH-2.0-WinSCP_release_4.3.5
. 2011-09-22 14:19:35.087 Waiting for the server to continue with the initialisation
. 2011-09-22 14:19:35.181 Detected network event
. 2011-09-22 14:19:35.181 Using Diffie-Hellman with standard group "group1"
. 2011-09-22 14:19:35.181 Doing Diffie-Hellman key exchange with hash SHA-1
. 2011-09-22 14:19:35.212 Waiting for the server to continue with the initialisation
. 2011-09-22 14:19:35.493 Detected network event
. 2011-09-22 14:19:35.556 Host key fingerprint is:
. 2011-09-22 14:19:35.556 ssh-dss 1024 ab:35:79:e7:f6:7d:b2:6d:99:d7:1d:52:01:8e:fa:b0
. 2011-09-22 14:19:35.556 Initialised AES-256 CBC client->server encryption
. 2011-09-22 14:19:35.556 Initialised HMAC-SHA1 client->server MAC algorithm
. 2011-09-22 14:19:35.556 Initialised AES-256 CBC server->client encryption
. 2011-09-22 14:19:35.556 Initialised HMAC-SHA1 server->client MAC algorithm
. 2011-09-22 14:19:35.556 Waiting for the server to continue with the initialisation
. 2011-09-22 14:19:35.915 Detected network event
! 2011-09-22 14:19:35.915 Using username "pfhp1425".
. 2011-09-22 14:19:35.915 Waiting for the server to continue with the initialisation
. 2011-09-22 14:19:36.009 Detected network event
. 2011-09-22 14:19:36.009 Prompt (7, SSH password, , &Password: )
. 2011-09-22 14:19:36.009 Using stored password.
. 2011-09-22 14:19:36.009 Sent password
. 2011-09-22 14:19:36.009 Waiting for the server to continue with the initialisation
. 2011-09-22 14:19:36.274 Detected network event
. 2011-09-22 14:19:36.274 Access granted
. 2011-09-22 14:19:36.274 Waiting for the server to continue with the initialisation
. 2011-09-22 14:19:36.368 Detected network event
. 2011-09-22 14:19:36.368 Opened channel for session
. 2011-09-22 14:19:36.368 Waiting for the server to continue with the initialisation
. 2011-09-22 14:19:36.774 Detected network event
. 2011-09-22 14:19:36.774 Started a shell/command
. 2011-09-22 14:19:36.774 --------------------------------------------------------------------------
. 2011-09-22 14:19:36.774 Using SFTP protocol.
. 2011-09-22 14:19:36.774 Doing startup conversation with host.
> 2011-09-22 14:19:36.774 Type: SSH_FXP_INIT, Size: 5, Number: -1
. 2011-09-22 14:19:36.774 Sent 9 bytes
. 2011-09-22 14:19:36.774 There are 0 bytes remaining in the send buffer
. 2011-09-22 14:19:36.774 Waiting for another 4 bytes
. 2011-09-22 14:19:36.868 Detected network event
. 2011-09-22 14:19:36.868 Received 38 bytes (0)
. 2011-09-22 14:19:36.868 Read 4 bytes (34 pending)
. 2011-09-22 14:19:36.868 Read 34 bytes (0 pending)
< 2011-09-22 14:19:36.868 Type: SSH_FXP_VERSION, Size: 34, Number: -1
. 2011-09-22 14:19:36.868 SFTP version 3 negotiated.
. 2011-09-22 14:19:36.868 Unknown server extension newline@vandyke.com="\r\n"
. 2011-09-22 14:19:36.868 We believe the server has signed timestamps bug
. 2011-09-22 14:19:36.868 We will use UTF-8 strings for status messages only
. 2011-09-22 14:19:36.868 Getting current directory name.
. 2011-09-22 14:19:36.868 Getting real path for '.'
> 2011-09-22 14:19:36.868 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
. 2011-09-22 14:19:36.868 Sent 14 bytes
. 2011-09-22 14:19:36.868 There are 0 bytes remaining in the send buffer
. 2011-09-22 14:19:36.868 Waiting for another 4 bytes
. 2011-09-22 14:19:36.962 Detected network event
. 2011-09-22 14:19:36.962 Received 35 bytes (0)
. 2011-09-22 14:19:36.962 Read 4 bytes (31 pending)
. 2011-09-22 14:19:36.962 Read 31 bytes (0 pending)
< 2011-09-22 14:19:36.962 Type: SSH_FXP_NAME, Size: 31, Number: 16
. 2011-09-22 14:19:36.962 Real path is '/HOME'
. 2011-09-22 14:19:36.962 Listing directory "/HOME".
> 2011-09-22 14:19:36.962 Type: SSH_FXP_OPENDIR, Size: 14, Number: 267
. 2011-09-22 14:19:36.962 Sent 18 bytes
. 2011-09-22 14:19:36.962 There are 0 bytes remaining in the send buffer
. 2011-09-22 14:19:36.962 Waiting for another 4 bytes
. 2011-09-22 14:19:37.040 Detected network event
. 2011-09-22 14:19:37.040 Received 21 bytes (0)
. 2011-09-22 14:19:37.040 Read 4 bytes (17 pending)
. 2011-09-22 14:19:37.040 Read 17 bytes (0 pending)
< 2011-09-22 14:19:37.040 Type: SSH_FXP_HANDLE, Size: 17, Number: 267
> 2011-09-22 14:19:37.040 Type: SSH_FXP_READDIR, Size: 17, Number: 524
. 2011-09-22 14:19:37.040 Sent 21 bytes
. 2011-09-22 14:19:37.040 There are 0 bytes remaining in the send buffer
. 2011-09-22 14:19:37.040 Waiting for another 4 bytes
. 2011-09-22 14:19:37.196 Detected network event
. 2011-09-22 14:19:37.196 Received 415 bytes (0)
. 2011-09-22 14:19:37.196 Read 4 bytes (411 pending)
. 2011-09-22 14:19:37.196 Read 411 bytes (0 pending)
< 2011-09-22 14:19:37.196 Type: SSH_FXP_NAME, Size: 411, Number: 524
> 2011-09-22 14:19:37.196 Type: SSH_FXP_READDIR, Size: 17, Number: 780
. 2011-09-22 14:19:37.196 Sent 21 bytes
. 2011-09-22 14:19:37.196 There are 0 bytes remaining in the send buffer
. 2011-09-22 14:19:37.196 Read file '.' from listing
. 2011-09-22 14:19:37.196 Read file '..' from listing
. 2011-09-22 14:19:37.196 Read file '835' from listing
. 2011-09-22 14:19:37.196 Read file '837' from listing
. 2011-09-22 14:19:37.196 Waiting for another 4 bytes
. 2011-09-22 14:19:37.274 Detected network event
. 2011-09-22 14:19:37.274 Received 26 bytes (0)
. 2011-09-22 14:19:37.274 Read 4 bytes (22 pending)
. 2011-09-22 14:19:37.274 Read 22 bytes (0 pending)
< 2011-09-22 14:19:37.274 Type: SSH_FXP_STATUS, Size: 22, Number: 780
< 2011-09-22 14:19:37.274 Status code: 1
> 2011-09-22 14:19:37.274 Type: SSH_FXP_CLOSE, Size: 17, Number: 1028
. 2011-09-22 14:19:37.274 Sent 21 bytes
. 2011-09-22 14:19:37.274 There are 0 bytes remaining in the send buffer
. 2011-09-22 14:19:37.274 Startup conversation with host finished.
. 2011-09-22 14:19:37.931 Session upkeep
. 2011-09-22 14:19:37.931 Detected network event
. 2011-09-22 14:19:37.931 Received 25 bytes (0)
. 2011-09-22 14:19:38.431 Session upkeep
. 2011-09-22 14:19:45.821 Closing connection.
. 2011-09-22 14:19:45.821 Sending special code: 12
. 2011-09-22 14:19:45.821 Sent EOF message
Re: 4.3.5 Stored host name in Scripting
The WinSCP instance running the script does not see the stored session.
You are probably using different local account that when you use GUI.
Please read FAQ:
https://winscp.net/eng/docs/faq_environment
OK, but you are using registry in script:
but INI file in GUI:
