5.0.2. beta password not remembered on background transfers
arf_uk
Using 5.0.2 on WinXP SP3 - running in 'Commander' mode.
I have 'Remember password of main session for background transfers' checked in the options, but all background transfer are causing prompts for password when carried out.
Also
I get the Invalid Access to Memory bug and the behaviour I notice is that it resets my local directory back to the installation directory. Hope this helps.
arf_uk
clarification
I should make this clear, that I'm using SSH key based authentication, and the password i'm being prompted for on every transfer is my SSH passphrase.
Sorry should have been clearer initially.
Re: 5.0.2. beta password not remembered on background transfers
WinSCP does not keep the passphrase in memory.
You can use pageant for that.
I'm sending you an email with debug version.
dlong500
I'm using 5.0.4 and having this problem. Note that I am NOT using keys or passphrases but simple password authentication.
I have the "Remember password of main session for background transfers" checked, but the first time I transfer a file after opening a session I get prompted for the password again.
This is definitely changed behavior from the 4.x versions I was previously using.
arf_uk
On v5.0.4 I'm still seeing this issue.
I've a mix of password sessions and saved keys but regardless everytime I initiate a transfer, I still get the problem.
Additionally on 5.0.4 I still get the Invalid Access to memory error on start up.
arf_uk
I can confirm that I still get these issues on 5.0.5.
Regardless, every time I initiate a transfer, I always get re-prompted for a password.
