A session based "Save file filter option"
WhoAmI
It would be great if the filter settings would be saved into the settings file.
I was trying to save my current defined file filter.
It seems that WinSCP doesn't keep this setting.
If I reopen the session, the file filter settings are lost.
In the ini file there is no such setting either.
I'm currently using WinSCP 4.3.5 (Build 1463)
mapsedge
persistent filters
Was going to request this myself. I'm glad I looked for it first. Throwing my voice to this request, too.
ers
Argentina
Panels filters
Can I always launch winSCP with filter mask for my remote panel in Commander view? Which raw setting would make it?
Re: Panels filters
No. That's what this topic is about. You can vote for the function in Tracker (the link is above).
