winSCP 5 "500 invalid PORT command
anlu42
I have recently upgraded to WinSCP 5 (Build 1431) (WinXP fully updated)
and since then I can not access a server which I frequently have been using for uploading files.
The connection is made via FTP
Check complete log of connection and login
https://pastebin.com/DN6c4bZG
Edit:
I can connect to server but not browse directories etc.
anlu42
Re: winSCP 5 "500 invalid PORT command
Hmm in 4.3.4 I have no recollection of making an active choice.
Thanks for the help.
How about the UNC path error which shows up in both versions?
Ankur Jain
Invalid Port Number
I am getting same error message when i am trying to connect to putty from winscp. It is working in latest final version. Thanks for your help
Ankur Jain
Re: Invalid Port Number
What version of WinSCP are you using? Have you tried 5.0.1 beta?
anlu42
I tried installing 501 but after installation it doesn't start.
Reverted to 4.3.4 and all works fine, still UNC-path error but I can use the software.
Why it did not start? Were you getting this error?
https://winscp.net/tracker/729
If you did, 5.0.2 should work for you.
anlu42
Don't know why, got no error message simply no reaction to double-click other then a flicker of an hour-glass. I'll try 5.02
5.02 works fine.
Still UNC-paths but as far as I can detect it is only one server.
Edit: I had \\servername\folder1\folder2\ as "home directory" for this session and when I changed it to c:\Documents...\username\Desktop it works fine. No UNC-path error
