Passwords do not get stored in WinSCP 5
Adambean
I'm having problems with stored passwords in WinSCP 5.0.0 (build 1431).
I use a master password, enter a password in the session form, ensure "Save password (protected by master password)" is ticked when saving the session. It prompts me for the master password and saves the session.
I can now connect without it asking me for the session (or master?) password. However after restarting WinSCP all saved passwords are lost.
Having checked the INI file (I use this over registry for roaming ability) the password tag on all the sessions is blank.
Adambean
Adambean avatar
Cardiff, South Wales
Nice, I see that it has already been resolved.
Probably useless now but the OS is Windows 7 Professional x64, so the INI file for me is at %LocalAppData%\VirtualStore\Program Files (x86)\WinSCP
I also see there are quite a few unreleased changes. Do you offer a latest build download?
Note that this won't work in 5.0.1 anymore, as this version disables file virtualization:
https://winscp.net/tracker/719
No. But new version will be release soon.
That means that you need to make sure you are running WinSCP from location where you have write permissions. Or that you need to specify alternative location for an INI file using /ini switch. There's actually nothing wrong on the article you refer to. But some note about the change might be worth it :)
NicoHaase
What about the footnote? Version 4.x used the virtualstore without any other settings, and this was removed according to bug 519. So, I think, this should be removed from the wiki ;)
Adambean
Adambean avatar
That means that you need to make sure you are running WinSCP from location where you have write permissions. Or that you need to specify alternative location for an INI file using /ini switch. There's actualy nothing wrong on the article you refer to. But some note about the change might be worth it :)
This won't be useful for multi-user computers.. I choose INI so it can be backed up, and sync'd to my file server so that I can get it immediately on my other computers.
Could we at least have the INI in %AppDir%\WinSCP if the process isn't running with UAC elevation?
So use the /ini switch.
INI file is target on portable use of WinSCP. E.g. from memory stick.
Adambean
Adambean avatar
Didn't know about /ini
"C:\Program Files (x86)\WinSCP\WinSCP.exe" /ini="%AppData%\WinSCP\WinSCP.ini"
^ works brilliant, thanks.
Also saved passwords appear to re-load from the INI when using a master password (5.0.1 build 1449). Thanks for this fix :)
Adambean
Adambean avatar
Hello and welcome to nearly 11 years ago. :)
Thanks for the update though, that's definitely a better default position for the INI file.
_________________
Thanks,
Adam Reece.
